997.2 C4 Brake Rotors
My front rotors will require replacement and I am unable to find any alternatives to the OEM. Ideally I was looking for a slotted disc but although there are several options for rear rotors, I cannot find anything for the fronts.
You might give PMB Performance a call http://www.pmbperformance.com/catalog.html
If anyone can get them, or have them in stock, it is Eric. Good luck.
Search for Sebro slotted if you track your car and just drilled if you drive on the street. It is even easier to find for non-S cars. You can start with http://forums.pelicanparts.com/porsc...s-sale-wanted/
05' C2S
05' C2S
I went with Giro Disk, Clark from Apex Performance set me up, great guy, tons of knowledge and superior service.
I know I have seen several possibilites, including Sebro and Giro mentioned above and Zimmenman. I'm leaning towards the Zimmerman coated rotors next time to prevent/reduce the dripping rust problem from the OEM cooling fins, but I think they only come in drilled. Both Pelican and Vertex Auto sell them as well as others.
Mike at Giro helped clarify the situation after some research,
- Front brakes are same as 981S fronts and even though the brake suppliers do not correlate these brakes with the 997.2 C4, all sets and components are compatible.
- Rear brakes are compatible with 997.2 CS rear brakes (this is correlated by most suppliers)
