Very noisy when first starting 997.1 TT
A couple of times recently, my '07 997 TT has been really rattle-y when I first started it. First time this lasted for about a second, today for about 3 seconds. After that, it dropped back to normal, and the car ran fine. It sounded like a loose chain maybe, so I wondered if perhaps there was a sticky tensioner? Any ideas?
ta
pete S
ta
pete S
ta
pete S
ta
pete S
could be normal tappet (valve lifter) noise. As the car sits oil slowly bleeds down from the tappets, and upon restart there is some noise as the pressure/wear compensation builds up again. It'll be especially noticeable if its cold out. also, jhbrennan is right. you should ask there too
ta
pete S
ta
pete S
I've been meaning to ask about this identical situation as it happens also to my 997.1 C4S, which has the 3.8 litre motor (about 12,000 miles on the car), under the same circumstances. Can get very loud, enough to draw the attention of neighbors, and not in a good way! I too would like to know the answer to this query. Thanks for asking, pete S.
