Need Help: Right side rear mirror keep turning itself up whenever I stopped driving
it's a 997.1 car, the right side rear mirror kept turning itself up(default setting?) whenever I stopped driving and turned off the engine, so next time getting on the car first thing I do is to turn it down. Not a big thing but sometimes I forgot to do it result in a ' all thumbs' situation when I was trying to change to the right lane on highway and couldn't see anything from right rear mirror before adjusting it...
Feel like a naughty kid teasing me... Anyone have similar experience?
Thanks.
The right mirror lowers when you go into reverse so you can see the wheel and not scrub it on the curb. How far it lowers can be set as well. But it only lowers if you have the mirror selector switch set to the right side.
Note ... I have noticed the left mirror adjust if I have the switch set to the left side, and neither mirror adjust if the switch is centered. I speak from 997.2 experience. Your 997.1 may be different.
I think the previous posts are correct, and here is why: I'm guessing you have a manual transmission and put the car in reverse gear when you turn it off. This triggers the movement to the preset reversing position which just happens to be set to up in your car.
Note that the movement to the reverse preset only happens if the mirror control is turned to select the right mirror, in any other position it is disabled. Since you have to readjust the right mirror each time you get in, you leave it turned to the right all of the time, therefore it is always enabled.
You can therefore quickly test to see if this explains your problem by simply turning the adjustment **** away from your right mirror and see if it stops happening. Assuming it stops, you adjust your preset as described in the manual as jhbrennan recommended and leave the mirror setting turned away from that mirror unless you want the setting that allows you to see the curb when parking and backing up.
