A little embarrased to ask: Changing the Battery
As with all cars - there's always something to consider.
I need to change the battery on my new to me 997. Before just changing it and having some oddball Porshce thing happen (ya know - where you say that you wish you had read the forum first) I figured I would ask. I used the search function and came up with nothing...
Is there any oddball thing that I need to consider - or can I just get a battery and replace the one thats in there now?
Replacing the battery is easy with no special concerns. You can get an H7 battery at Walmart ( that's what I did). Just check the date of manufacture ( printed or sticker on top of the battery). You will want one that is less that six months old.
You may want to charge the battery before installing it. Remove the old batter and install the new one making sure the vent tube is hooked up and follow all standard safety practices. Standing in the trunk makes the process much easier.
There will be two minor procedures to carry out. (1) Re-set the windows by closing them, opeing them and closing them again until the the limit switch is activated ( it's in the manual). (2) There will be an error warning for the PSM. Simply turn the steering wheel all the way left and then right. The drive the car straight for about a 1000 feet and you will then be all set.
Finally, do not replace the battery if you are planning to get the car inspected by the state within a few days as any fault codes will have been cleared and the car will need to be driven for a few days under different circumstances before the the systems will indicate they are " ready". ( give yourself a week to be safe)...... that's it!
Rat Balls
Replace battery
I looked in the manual and couldnt find any special instructions on replacing the battery other than simple common sense, no special instructions were added? Where might I find these special things to do in the book,under what category? 2011 carrera 911s. Thanks for any help
The most important thing is to not put the new battery in backwards. It may seem silly to say, but the terminals are not well marked and it has happened to others before.
Also, if you have a trickle charge and hook it up it will supply enough power so that the ECU will not "know" that the power has been interupted. At least that's what my Indy did when he changed my battery and there were no fault codes or resets required. (Yeah, I know it seems lame to have an Indy change a battery but there is no way I wanted to risk wrenching by back. I bought the battry from him and I think gave him $25 for his trouble - well worth not being in pain for a week.) Anyway, don't forget to hook up the cables to the proper terminals and ground, etc, etc. etc.. I recall horror stories I read here from people who made these simple mistakes.
I almost made the charger suggestion (battery maintainer into one of the outlets) but then balked. It's a great idea as long as you don't short the cables (like touch them both to frame) when you change the battery. But when you change the battery you release the cables to put the new battery in. You lose control of what they touch. Some pieces of card board or rags may save you from replacing a fuse and then resetting you windows.
Yes, I did that. Blew the fuse on the back of the radio. Took me three weeks to find out there was a fuse on the back of the radio. So much fun.
