Any help with a wiring schematic, wiring harness or connector for a sport chrono that will be retrofitted into my 57 356 A coupe (if it's even possible) would be welcomed? Thanks in advance!
Concur with Cam above. I had a bit of a rattle in mine and popped it out and added a tiny rubber washer in the pivot to stop the rattle. It has a metal spring tab holding it in.
Just use a trim tool, or any thin prying tool to pop it up from the front. Be sure to use a thin magazine or something to protect the dash surface from the tool.
Concur with the above. I replaced mine with a leather unit. Just pop it out with a trim tool and unplug one connector after you pop it out. No problems, no warning lights, no rattles.
Pic? Did you have the "leather unit" custom made, or is there a ready-made piece?
Not sure if I saw it on this forum... but someone without the Chrono option install a 3rd party gauge / meter by buying the original Chrono pod and drilling a hole on top of the dash board without even taking it off!!!
Originally Posted by kotzankov
Has anyone been able to retrofit to a car that did NOT come with one? I kind of like the look and am hoping I can add to my '07 C4S...
