Anything new for steaming audio?
Rat Balls
I have the Tune2Air but the well documented issues with it cutting in and out weren't resolved when I switched from an iPhone 4s to a 5s. I actually think it's worse now. Has anyone come across a new product that actually works?
I'm using the Mobridge M2 Pro in my 997.1 turbo. It works perfectly for bluetooth streaming audio. Track information is displayed on the PCM screen and I can skip songs backward or forward with the controls on the PCM. It has more functionality if I plug it into the USB port like playlists, searching by artist and track, etc. I don't know if this would work with the newer PCM 3.0 or not.
You weren't in SoCal a couple of weeks ago? A car like a lot like yours parked next to mine.
Traded emails with the Tune2Air folks when I first got the device and they did not have a fix. Seems to be an issue with PCM as there is not a problem with BMW.
Don't take many calls from my car so don't miss the phone connection to the PCM.
Don't have the navigation module, so I just Maps app on my phone for the audio instructions that run through the stereo.
Streaming audio like Pandora is just perfect no skips. I listen to more music than talking on the phone so this work around works for me.
I do have PCM 2.1 with navigation and Bose. I had the system professionally installed. I think the installation was around $120 plus the cost of the unit. The unit also provides bluetooth telephone connectivity, iPhone/iPod charging and the ability to stream iTunes, Pandora, Spotify, etc.
I wasn't in CA - at least not with my car!
I have a MY05 with whatever PCM it came with, BOSE, no NAV. I have the Tranzit-Blu HF. I stream Spotify (I have a premium account which lets me sync my playlists offline so I don't use data minutes unless I want the Spotify radio function which I rarely ever use). Also does handsfree phone, and GPS by bluetooth from my iPhone 5. Great sound, no cutting out, phone and GPS mute the music. Song title and caller ID show on the PCM screen, but playlist and GPS map are on the iPhone screen (I set the phone in front of the shift leaning against the center dash under the A/C control. Siri will open Spotify and make calls etc. and the Tranzit-Blu control button does answer/hangup and song skip with s single press. For such an inexpensive unit it works flawlessly and I'm happy.
Tranzit is as good as it gets without spending too much. I installed mobridge, dension, navtv units for customers which have better sound (not a whole lot unless you are absolutely picky) and few more options but 5-6 times more expensive and more work.
