Brake service light came on
10-07-2014, 11:58 PM
AddictRennlist Member
How do I know which ones need replacing?
Caesar
10-08-2014, 12:54 AM
You're most likely going to have to visually inspect the pads and see which ones wore down to the brake sensor.
10-08-2014, 10:12 AM
Yep, visual inspection. Might be able to tell with the wheels on, but easily found with them off.
10-08-2014, 12:24 PM
my understanding was that two pairs of fronts to every pair of backs.
10-08-2014, 12:50 PM
Quote:
Originally Posted by
3point8
probably. much more disparity if you track it.
in any event, in order to save $ at the stealership, best to tie back those sensors anyway and monitor visually/routine maintenance inspection.
10-08-2014, 01:46 PM
3point8
That's the way I'd do it.
