Anti-submarine mount: drilled and mounted through chassis vs Brey-Krause
Spoke with TC Design on Friday, our local fabrication specialists, regarding an anti-sub mount point. When I asked which they'd recommend, they actually said either solution would work well. Porsche uses a larger bolt to mount their seats than other companies, so the difference between the bolt on BK mount and a drilled solution is negligible. Just a FYI!
