SOS - My Coolant Tank Is Stuck!
Pelican mentions an air pump removal thats not needed.
It also neglects to mention that you need a deepset 18mm socket to remove the engine bar.
I did not remove the black bracket that holds in the tank. Pushing the tan forward allows you to get the tank out of the bracket a bit easier. Even with the motor at its lowest point - getting the tank out it still a bit of a miracle. You move all the pipes you can - grab it - close your eyes and pull. hoping for the best. Not an approved porsche tech procedure...
