Oil temp 2006 997S
My Indy says don't worry about it. Seems high but I know that outside of getting to a "normal operating temp".... Higher long term temp isn't always good.
Any opinions? As far as I know I have a stock thermostat....
997.1 - in HOT weather crappy traffic, i've seen my oil temp go as high as 225.... but when cruising 60-80 mph the car cools back to 200.
while i don't expect much diff, i'm curious if these numbers will change at all after doing the oem 997.2 end conversion, supposedly there should be even more airflow to the rads during normal highway driving with large center deflector/radiator shrouds
http://www.machinerylubrication.com/...lubricant-life
Cliff notes:
"In 1903, Arrhenius won a Nobel Prize when he figured out the relationship between temperature and most chemical reaction rates. Often called the Arrhenius Rate Rule, it relates to the fact that lubricants, once they've exceeded their base activation temperature, will degrade (oxidize) twice as fast for every 10 degrees C (18 degrees F) increase in temperature. In fact, there are a range of problems associated with too much heat, such as:
• Additive and base oil decomposition is accelerated.
• Some additives will volatilize and escape into the atmosphere.
• Viscosity-index improvers shear down more rapidly.
• Microbial contaminants prefer warmer temperatures (but not scalding).
• Heat collapses oil films, causing accelerated abrasion and scuffing conditions.
• Hot oil shortens the life of filters and seals and accelerates corrosion.
• Both oil and grease are more prone to leakage.
• Grease separates faster (oil from thickener) at elevated temperatures.
• High surface temperatures can form carbonaceous gum and resins."
Most don't change, or think to have a shop change, the thermostat when even replacing the infamous waterpump. Worth the small investment if it means a 10-20 degree difference in average oil temp over the life of your car, especially on track.
