GT3 LCAs
A few questions about LCAs:
- How much adjustment compared to stock 997?
- Are they front and rear LCAs available?
- Will i notice any actual difference on H&R springs?
- Dare i ask...how much?!
Thanks!
They will certainly add additional camber, which one would assume is your goal. With springs and front LCA's you should easily be able to achieve -2.5, perhaps more. A bit useless in the rear as you can already dial in that much on your existing parts. Will increase your front track marginally also but you could do that with spacers just as easily. So again, really comes down to what you're goals are.
http://www.tarett.com/items/996-997-...kit-detail.htm ~$1,000 plus you'll need shims, install, and alignment.
