Caliper rebuilding components
Former Vendor
Caliper Rebuilding Instruction just got updated in our new website here:
Thank you for your support in the past years and we are proud to be your trusted source in making your calipers perform better and last a lot longer than original.
https://racingbrake.com/instructions/
Please feel free to add your comment & experience; including your suggestion to make this instruction easier and friendlier for other Porsche DIY ownersThank you for your support in the past years and we are proud to be your trusted source in making your calipers perform better and last a lot longer than original.
https://racingbrake.com/porsche-4/
Hey Racing Brake! I did the update on my 997.1, I am looking for brake pad dampeners to reduce the noise under braking, the existing OEM dampers move excessively in my new thin-walled pistons. What size dampers should I be moving up to?
Fronts OEM: 40/36
Rears OEM: 30/28
Last question: is there a high-temp silicon brake grease/lube that doesn't react with the blue, high-temp piston dust boots?
Thanks!
Fronts OEM: 40/36
Rears OEM: 30/28
Thanks!
I'm just wondering what the advantage of thin-walled steel pistons is. Assuming the same heat development during braking, more metal naturally stores more heat (lower peak temperature), while thin-walled pistons inevitably reach higher temperatures and naturally release this heat into the overall system, preferably the brake fluid.
