Coolant low. Crud on bleeder valve.
Old Apr 19, 2014 | 07:40 PM
JCGMS's Avatar
JCGMS
Default Coolant low. Crud on bleeder valve.
Hi Everyone,
2006 C2 65,000 miles.
Last week when changing oil I noticed my coolant level was low (about 1/4 inch below min) and there was crud around the seam of the bleeder valve. I've had no error messages or warnings, and coolant temp is always 175 after warm up. My water pump was replaced about a year ago.
I cleaned it off and after driving for a week the level seems about the same and there is a very very light buildup of crud. A few questions:
1. Could having the old .01 type coolant cap have anything to do with this? I have a newer .04 rep to replace it with.
2. OK to top off with distilled water for now? I don't want to spend a bunch on P coolant if I'm gonna end up replacing tank anyways.
3. Do I need to do any sort of bleed procedure to top off correctly?
Any insight would be appreciated.
File Type: jpg
Old Apr 19, 2014 | 08:35 PM
floatingkiwi's Avatar
floatingkiwi
Looks like your bleeder valve has got a leak mate.
Old Apr 20, 2014 | 12:30 AM
JCGMS's Avatar
JCGMS
Forgot to mention I had tightened the screws, with the exception of the back corner one which is hard to get too. Didn't tighten too much for fear of messing something up. The only reason I asked about the cap is because the guy at the parts shop thought that may have something to do with it. I haven't read about anyone replacing just the valve....has anyone done this?
Old Apr 20, 2014 | 04:18 AM
floatingkiwi
The cap will make no difference. The earlier caps leaked out past the cap slightly. You need to replace the bleeder valve assembly.
Old Apr 20, 2014 | 09:07 PM
Dadio's Avatar
Dadio
I would agree with that. While a new bleeder valve can be ordered, replacing the coolant tank , which includes a new bleeder valve , would be my approach. Not sure if they come with a new cap but it should also be replaced with version 4 while you're at it.
Old Apr 21, 2014 | 01:02 PM
BIG smoke's Avatar
BIG smoke
My pump was leaking and I had a crack in the tank. Double check your whole tank before you replace "just the Valve"?
Old Apr 21, 2014 | 02:15 PM
Rotmilky's Avatar
Rotmilky
My reservoir developed a crack in it around 65,000 miles. Those can be the devil to find. As suggested above, consider replacing the whole reservoir.
Old Apr 21, 2014 | 02:48 PM
JCGMS's Avatar
JCGMS
Agree with everyone above about considering replacement of the whole tank, especially since it seems like only a matter of time before they fail (wish I had known when I had the water pump replaced).
I'd hate to replace the whole thing if it's something simple like an O-ring in the bleeder valve that I could potentially DIY myself though.
Old Apr 21, 2014 | 05:16 PM
mango60l's Avatar
mango60l
3rd Gear
I recommend you replace the tank. I just did the job on Saturday and it only took a couple hours. The tech article by Pelican Parts made the job pretty easy. I did have to lower the engine because there isn't much room in the C4 engine bay to wiggle it out.
I rebuilt my bleeder valve about two months ago. I replaced the two o-rings and the eight bolts on top. It stopped the crud build-up, but I noticed a leak in the tank last week. Once I pulled it out, the leak was in the exact spot as BIG Smoke's. The original tank lasted just over 77k miles.
Old Apr 22, 2014 | 01:53 PM
Rotmilky's Avatar
Rotmilky
My reservoir was cracked on the backside of the support in the center. Photos and info on how I removed my reservoir are in this thread:
https://rennlist.com/forums/997-foru...997-1-a-2.html
Old Apr 23, 2014 | 10:04 PM
JCGMS's Avatar
JCGMS
Thanks. That's a great DIY. I'm probably gonna top of with distilled water, tighten the bolts a smidge, and take it to get replaced if I see the level drop at all again.
Old Apr 24, 2014 | 04:49 AM
mlv_250's Avatar
mlv_250
I too am planning to flush coolant & change out tank & cap and was wondering if there are any hoses that should be swapped out for new? 2007 C2 with 60K mi no track. Thx
Old Jul 1, 2014 | 01:42 PM
levdeb's Avatar
levdeb
Great tips guys...!
