Ultimate street survival / track attack combo
Old 04-17-2014, 11:43 PM
1990nein
1990nein's Avatar
Default Ultimate Street Survival / Track Attack combo
How to transform your car from a factory beast into the incredible hulk!
Tires
Yokohama Advan Neova AD08R
The AD08R is currently the most awesome tire you can get. It is a refresh of the proven AD08 and is also the “freshest” tire in its category to hit the states. There are other brands I would have liked to consider, but there simply weren’t any offerings in the 19” wheel size that were attractive enough to compete with the AD08R. I also would have liked to consider BFG Rival, Dunlop Direzza ZII, Continental RE-11A, and Hankook RS-3, but as of 2 months ago none of them were offered for 19”. The Rivals and ZII may end up being a little faster, but lap times should only differ by a small margin, and for intended purposes the trade-offs in streetability and weird slip angles would not have put them at the top of the list.
The Bridgestone RE-11A, which received an update last year, would have been my second choice behind AD08R, but only the old RE-11 version of this tire was available in 19.” The Hankook RS-3 is very fast and proven tire, and seems to have popped up on Tire Rack in 19" at the time of this writing. Although Hankook re-labeled them as 200 UTQG tires last year, the tread pattern and compound appears to have been unchanged since they were first released back in 2009. They’re still a very competitive tire, I just don't like the idea of paying new money for old technology. The same goes for the OEM Bridgestone RE50A - even the N1 version of the RE50A is relatively outdated by now, but still costs more, has less grip, and will wear faster.
The AD08R’s replaced Michelin Pilot Super Sports. I really liked the MPSS on the street. They are superb in the rain, long lasting and will allow you to whip around the occasional corner at speed. It is too bad they are desperately inadequate when it comes to extracting performance out of a sports car. If you try to throw more than a few corners at the MPSS, they will grease up very quickly and start to disintegrate. Anything above 40psi and its slip ‘n shred; anything below 37psi and the sidewalls roll under; the only thing you’re left with is 3 PSI to do parade laps or rain driving.
Brake Pads
Endless MX72
Brake dust alone is a good enough reason to switch from stock pads. The MX72 pads are carbon ceramic and the amount of brake dust compared to stock has been reduced by at least 80%. Feel is more responsive and modulation is very accurate – it is easy to consistently scrub off a precise amount of speed. The pads are also whisper quiet with zero squealing or creaking. They were installed on new stock rotors. Something to mention is the MX72 pads are hesitant to stop when they are cold. A minor annoyance, but after a few initial stops to warm them up, the MX72 blow the stock pads out of the water in every way. The increased stopping power and control over braking is confidence inspiring and makes the car more engaging to drive.
Pagid, HPS, Hawk, Carbotech, etc. are popular brands but I didn’t find anything that really stood out from them. Like the AD08R, the Endless pads were an easy choice when it came to having the best combination of dual-duty performance. Also to note is that the MX72 seems to have been updated with a newer compound called the MXRS, but at the time I could not find sizing for 997.
Brake Fluid
Castrol SRF
It’s the best fluid on the market. Do your research and you’ll find the same information – OEM and Motul will need to be bled after any serious track use, SRF has been known to last many an entire season. It’s a no brainer; even if it seems absurdly expensive, the overall cost is the same if you bleed/flush mid-season with cheaper fluid, and you keep higher quality fluid in your lines.
Nitrogen
Nitrogen is free for Costco members. Take advantage of it, there's no reason not to. There is a portable compressor in the frunk if you need to add air, otherwise just top off your nitrogen at Costco. If you don't want to get nitrogen, just make sure the air you pump is dry.
Alignment & Pressures
Max out the front camber (-1), max out the rear camber (-2), neutral front toe or slight toe out (.00-.08), and rear toe-in (.12-.32). This is a “when in doubt, throttle out” safety alignment – the setup gives the rear wheels a serious tendency to push the car straight, so if you get yourself into trouble you can just kick the throttle to reduce any unwanted rotation.
Start at .24 for rear toe-in, dial it up if find yourself spinning out easily, or dial it down if you find yourself understeering too much trying to get around the corner. For front toe, start at neutral and dial it out as you want to increase turn-in response.
With stock size 235/305 AD08R tires, I’ve used:
36/40 for street
33.25/38.5 for autocross
35-36/38-39 hot pressures coming off the track.
AD08R don't really get hot unless there is a lot of friction/slip. For DE or conservative practice, warm up to 38PSI and the tires are very easy to keep consistent for entire session. For time attack, 39 very hot in the rears will let you stomp out of corners like you are on R compound.
Tire Tools
Pick up Joe’s Racing tire gauge and Milton tread depth gauge, they are $20 and $5 on Amazon. Very handy tools that you can keep in the frunk box. If you want an infrared thermometer, Etekcity/TopG Dual lasers are quality meters for $25 on Amazon as well.
Other Tools
Harry's Lap Timer for Android or Iphone, $9-$20.
Mountek CD slot mount, $20 on Amazon.
Package in action!
Old 04-18-2014, 01:03 AM
alexb76
alexb76's Avatar
Tires
The Continental RE-11A would have been my second choice behind AD08R, but only the old RE-11 version of this tire was available in 19.”
You mean, Bridgestone RE-11, right?
Old 04-18-2014, 01:32 AM
1990nein
1990nein's Avatar
Old 04-18-2014, 11:35 AM
z3mcoupe
z3mcoupe's Avatar
Great information, thanks for posting . I will be auto x'ing the targa in two weeks so having an idea of tire pressures is really handy.
Luckily when I bought it the seller had just installed a set of RE11's. I will get the GoPro charged and ready!
Old 05-07-2014, 07:36 PM
THE_Roen
THE_Roen's Avatar
I like flushing before every track event with RS683.
MPSS shouldn't be in the same category as any of the other tires you listed.
Old 05-07-2014, 10:13 PM
vern1
vern1's Avatar
Good info thanks
Can anyone tell me about this two feet in in a spin though??
Old 05-08-2014, 02:47 AM
Hatzenbach
Hatzenbach's Avatar
Originally Posted by vern1
Good info thanks
ROFL
Old 05-08-2014, 06:34 AM
sjfehr
sjfehr's Avatar
The rubber compound on the Hankook RS3 has been updated, but they did not change the designation. The only way to tell is by the date code. IIRC, dates after APR14 are all the new compound. Anecdotally, grip is the same with the new compound, but it provides that grip at lower heat levels now. People are calling it "v2" on the internet, and TireRack changed the part# in their system to avoid confusion.
Hankook claims the RS3 was always a 200TW tire, they just called in a 140TW for marketing purposes... until all the popular racing series that used it required tires to meet 200TW. Rumors abound that Hoosier will do the same for the R6 & A6, lol.
Old 05-08-2014, 11:42 AM
dw.metro
dw.metro's Avatar
Tell us more about the brake dust from the ceramic brake pads.
Old 05-08-2014, 01:25 PM
user 72902
user 72902's Avatar
Good info thanks
Its an old racing trick. Place both feet on the gas pedal to accelerate faster.
Old 05-08-2014, 02:00 PM
PJorgen
PJorgen's Avatar
After watching your auto-x videos I'm not sure I'd trust your recommendations.
Old 05-08-2014, 03:16 PM
alexb76
alexb76's Avatar
+1
Tires are personal IMO, and many of the top brands would do, MPSS is a great compromise for track/street, while some of the more aggressive tires like RE-11 would go better on track, not so in rain.
For pads, one pad EVERYONE MISSES, is Ferodo 2500! I've been using it for a few years and it's absolutely THE BEST pad for both street/track, nothing else I've tried on GTI, S4, RS4, 997, and from all reviews could do what 2500 can do. It does very well on the street, and yet on track (with street tires) it just grips and grips with no fade! Can't recommend it highly enough.
Old 05-08-2014, 07:15 PM
PJorgen
PJorgen's Avatar
Originally Posted by alexb76
+1
I think you're the only other poster I've seen who used the DS2500. I've always touted them as the best combination street/track pad. Pretty good price too when compared to Pagid, etc.
Old 05-08-2014, 07:26 PM
alexb76
alexb76's Avatar
I know, Porsche folks have a crazy loyalty to Pagid, and while Pagid is excellent for track use, or pure street use, no Pagid that I've seen does as well as DC2500 on both street and track, if you get a chance try em next time, they also last a very long time!
Old 05-08-2014, 10:32 PM
GermanCarSpecialists
Former Vendor
GermanCarSpecialists's Avatar
Huge fan of ferodos here. Pagid sport is not bad for street either.
Quick Reply: Ultimate street survival / track attack combo
