P0660, P1043, P0420, P0430 on 2006 C2S (X51)
I've posted this inquiry on a couple of other sites, but I'm not really getting much feedback. Hopefully you experts can help me out.
I Recently picked up a 2006 C2S, with the Carrera Power Kit (X51), and it has about 22,000 miles.
Car has been running fantastic, until the other day threw the check engine light. I ran a scan, using the Durametric, and below are the results that I'm most concerned about (There were a few others, which I'll try to address later).
I'm mostly concerned about the P0660 and P1043.
I've done quite a bit of research, but basically I'm back to square one. I do have the service manuals, but am having trouble locating what exactly the issue is. Car is still running fine (to me), but would like to get these addressed before a bigger problem occurs. Any help or assistance would be greatly appreciated.
Note, I believe P0420 and P0430 are being thrown due to the Fabspeed aftermarket exhaust that is installed. I'm thinking that I can install some spacers for the O2 sensors to help alleviate this issue. Please advise if I'm correct.
The log of the codes is as follows: (P0660, P1043, P0420, P0430).
Bosch Digital Motor Electronics Motronic 7.8.1
Module Identification
Part Number 997.618.624.06
Supplier Part Number 00419100A822
Current Fault Codes
P0660
Intake pipe switchover final stage
Freeze Frame Information
Fault symptom open circuit
Self test not complete
Fault status fault not present
Warning light off
Fault path num 50176
FLC/HLC state 10
Fault check state 0A
FCM line status 00
FCM output data (mil, svs) 44
Error Path Status 1537
Counter Continuous Error 0
Counter Accumulated Error 65280
MIL on counter 255
MIL off counter 12
Clear counter 40
Frequency counter 1
Calculated LOAD value 91 %
Engine coolant temperature 72 °C
Short Term Fuel Trim - Bank 1 0 %
Long Term Fuel Trim - Bank 1 0 %
Short Term Fuel Trim - Bank 2 0 %
Long Term Fuel Trim - Bank 2 0 %
Vehicle speed sensor 0 km/h
Ignition Timing Advance for #1 Cylinder 0 °
Intake Air Temperature 37 °C
Absolute Throttle Position 13 %
Commanded Secondary Air Status 04
Commanded Evaporative Purge 0 %
Barometric Pressure 1000 kPa
Relative Throttle Position 1 %
Ambient air temperature 3 °C
Absolute Throttle Position B 12 %
Commanded Throttle Actuator Control 2 %
Long term secondary oxygen sensor fuel trim - Bank 1 0 %
Long term secondary oxygen sensor fuel trim - Bank 2 0 %
Fuel system 1 status 067F
Engine RPM 128 rpm
Air Flow Rate from Mass Air Flow Sensor 2 g/s
Absolute Load Value 46 %
Total operating time (first occurrence) 760.3 h
Total mileage (first occurrence) 36186 km
P1043
Exhaust flap control final stage
Warning light off
Fault path num 50432
FLC/HLC state 10
FCM line status 00
MIL on counter 255
MIL off counter 12
Clear counter 40
Frequency counter 1
Engine RPM 128 rpm
P0430
Bank 2 catalytic converter system insufficient effect
Fault symptom below limit
Warning light off
Fault path num 29696
FLC/HLC state 10
Fault check state 0B
FCM line status 10
FCM output data (mil, svs) 22
Error Path Status 769
Counter Accumulated Error 512
MIL on counter 2
MIL off counter 3
Clear counter 40
Frequency counter 5
Calculated LOAD value 28 %
Engine coolant temperature 63 °C
Long Term Fuel Trim - Bank 1 4 %
Short Term Fuel Trim - Bank 2 -1 %
Long Term Fuel Trim - Bank 2 5 %
Vehicle speed sensor 67 km/h
Ignition Timing Advance for #1 Cylinder 42 °
Intake Air Temperature 18 °C
Absolute Throttle Position 18 %
Barometric Pressure 980 kPa
Relative Throttle Position 5 %
Ambient air temperature 4 °C
Absolute Throttle Position B 17 %
Commanded Throttle Actuator Control 7 %
Fuel system 1 status 147F
Engine RPM 2432 rpm
Air Flow Rate from Mass Air Flow Sensor 20 g/s
Absolute Load Value 51 %
Total operating time (first occurrence) 748.7 h
Total mileage (first occurrence) 36192 km
P0420
Bank 1 catalytic converter system insufficient effect
Warning light off
Fault path num 29440
FLC/HLC state 00
Fault check state 0D
FCM line status 10
Error Path Status 768
MIL on counter 2
MIL off counter 2
Clear counter 40
Frequency counter 3
Calculated LOAD value 35 %
Engine coolant temperature 87 °C
Short Term Fuel Trim - Bank 1 4 %
Long Term Fuel Trim - Bank 1 2 %
Short Term Fuel Trim - Bank 2 2 %
Long Term Fuel Trim - Bank 2 3 %
Vehicle speed sensor 93 km/h
Ignition Timing Advance for #1 Cylinder 41 °
Intake Air Temperature 31 °C
Absolute Throttle Position 19 %
Relative Throttle Position 7 %
Ambient air temperature 21 °C
Absolute Throttle Position B 18 %
Commanded Throttle Actuator Control 9 %
Fuel system 1 status 197F
Engine RPM 2304 rpm
Air Flow Rate from Mass Air Flow Sensor 26 g/s
Absolute Load Value 55 %
Total operating time (first occurrence) 750.2 h
Current Fault Codes
P0660
Warning light off
FLC/HLC state 10
FCM line status 00
MIL on counter 255
MIL off counter 12
Clear counter 40
Frequency counter 1
Engine RPM 128 rpm
P1043
Warning light off
FLC/HLC state 10
FCM line status 00
MIL on counter 255
MIL off counter 12
Clear counter 40
Frequency counter 1
Engine RPM 128 rpm
P0430
Warning light off
FLC/HLC state 10
FCM line status 10
MIL on counter 2
MIL off counter 3
Clear counter 40
Frequency counter 5
Engine RPM 2432 rpm
P0420
Warning light off
FLC/HLC state 00
FCM line status 10
MIL on counter 2
MIL off counter 2
Clear counter 40
Frequency counter 3
Engine RPM 2304 rpm
not sure what you can do with this but FWIW:
P0420, P430
Catalytic conversion
NOTE
The catalytic converter monitor compares the amplitude of the oxygen sensor behind the catalytic converter with the amplitude of a computed limit catalytic converter during defined air gulping and enrichment phases. The amplitudes allow conclusions to be drawn about the ability of the catalytic converter to store oxygen.
Diagnostic conditions
- Engine start temperature > -15°C (5 °F)
- Catalytic converter temperature 385 .... 635°C (725-1175 °F)
- Loading of activated charcoal filter < 8
- Oxygen sensing in front of catalytic converter active
- Oxygen sensors behind catalytic converter ready for operation
- 50 seconds (cumulative) within following load/rpm range
- Engine speed 1280 .... 2880 rpm
- Engine load (relative filling) 22 .... 41%
- No fault oxygen sensors, tank vent, secondary-air pump relay, secondary-air valve relay, throttle adjusting unit, mass air flow sensor, no misfire.
The diagnostic conditions can also be established using the PIWIS Tester via the short test "Catalytic conversion". It is not necessary to have the vehicle in motion for this.
Possible fault causes
- Oxygen sensors in front of and behind catalytic converter swapped (position in exhaust assembly)
- Valve lift error
- Aged oxygen sensor behind catalytic converter
- Catalytic converter faulty (pre-catalytic conversion rate too low)
P0660
Electric tuning flap
- Power supply voltage > 7 V
- Engine start-up and subsequent engine running > 10 s
- Short circuit to B+/ground or open circuit in the control line
- Open circuit of power supply to tuning flap solenoid valve
- Tuning flap solenoid valve faulty
- DME control module faulty
P1043
Electric air cleaner flap
- Open circuit of power supply to air cleaner flap solenoid valve
- Air cleaner flap solenoid valve faulty
P0420, P430
NOTE
- Valve lift error
P0660
P1043
Thanks fella's for your reply. I did run across that documentation regarding the tuning flap and air cleaner flap, however, since I have the X51 air box and intake, I don't have those solenoids. The X51 intake is different than the S intake.
Just to double check my thoughts, last night I took the air intake apart, up to the Throttle Body. Basically, there is only one sensor in that whole path. The MAF sensor. All the ports in the Carbon intake are all open all the time. So, it basically goes Filter, through MAF, directly the the Throttle body.
With that being said, I'm wondering if the P0660 and P1043 are even valid codes in my situation. Grant you, the X51 was a factory installed option on my C2S. SO, I would have assumed that this code would have been flashed out from the factory, but, I can't be certain.
Any additional thoughts? Thanks for your input guys.
