PDK Racing steeringwheel
There is a 'plug and play' racing steering wheel for the new Porsche 991 and 981. The functions Sport+, Sport and PSM can be switched on or off from the steering wheel buttons. A LED indicator bar gives you feedback if a function is activated. There are three different LED intensities which you can set with the DIM switch. The upper two switches are free to use for your specific application. A special glow in the dark foil is applied for night usage.
You can take the steering wheel out of the car with a quick release adapter. A curly wire with autosport connector is used to connect the steering wheel to the hub. The complete plug and play wiring comes with a toggle switch which let you choose to use the steering wheel or the mid-console switches. The system is completely reversible with the original steeringwheel. The Porsche 997 and 987 steering wheel kit is also available. PDK Racing steeringwheel
The system is designed for use for motorsport purposes only and not to be used on public roads.
