PASM issues?
Old Mar 31, 2014 | 12:27 AM
Sugar997's Avatar
Sugar997
Default PASM issues?
I have a 2006 C2s with 80km. Just had H&R springs installed. Since the install (two days ago) the car in seems to be stuck firm mode. If I push the "sport" button it lights up but the shock button does not light up. The screen says pasm sport on as normal. When I re push sport to turn off the reverse happens but it's still in firm mode. If I push just the shock button nothing happens.
Any ideas of what is going on?
Old Mar 31, 2014 | 02:32 PM
Spiffyjiff's Avatar
Spiffyjiff
are you sure you reconnected all PASM wires? i would disconnect battery, disconnect PASM wires/clean the contacts/reconnect, reconnect battery. if that doesnt work, check out if there's any error codes using OBD reader.
