GTS question
GTS question
Does the 2011 911 GTS Cab without the Sport suspension option have the same suspension as the 911 S Cab and same ride height?
Question comes from driving both today and I'll say no. The regular PASM setting on the GTS seemed the same as the PASM+ setting on the S. The GTS' top seemed to rattle and squeak quite a bit, but that could have just been the windows needed lubed. I've read a couple other threads and they didn't seem to directly answer this.
Thank,
Dan
Thank,
Dan
Thank,
Dan
Thank,
Dan
Btw, greetings to another fort worthian..
Thank,
Dan
Thank,
Dan
Anyway, I was surprised that most of the squeaking comes from the lower rear edge of the top, where the thicker rubber gasket seal sits on the ledge of the car when the top is fully in the closed position. You partially open the top to fully expose the gasket seal. He then carefully rubbed the lube into the seal that runs along the complete lower edge of the top. He did the same to the seal that runs along the front edge of the top (the thicker rubber seal that rests on the top of the windshield frame when the top is closed). He said these are the two seals that cause 90% of the squeaks. He then did the same to the window seals, and to the joints in the convertible top frame.
Afterwards, the squeaks that were driving me nuts were gone. He told me to do the same again in about 2 days, and I should be good for 6+ months.
My car sat at the dealership when new for a period of time before I bought it. While it spent most of the time inside on the showroom floor, they did display it outside on the weekends. The mechanic said that causes the seal to get dry and start the squeaks.
I've tried other rubber lubricants before like Gummi-fledge, etc. and nothing works as well as the stuff they gave me at the dealership. I started using it on the seals of our BMWs and it works great. Hopefully, when I run out, I'll be able to find it cheaper some place.
When I return to my car, I'll try to remember to look at the tube and post the name.
Look up the specs on the GTS. It is lowered as compared to the S.
Yes saabin I test drove the GTS Cab yesterday followed by the S Cab at ParkPlace Porsche. The GTS is very nice. I went into the test drive thinking the two would be pretty similar after reading several threads on similar topics that indicating they would be. After driving it I came to the conclusion I couldn't drive it everyday, but boy oh boy it sounded great and drove really well regardless of my dislikes. A great side benefit was driving a PDK for the first time. I was impressed with that.
Thanks beden1 on the top squeaking. That's what I thought. The car was dirty and lubing of the top has probably never been done. Good tip on the Porsche product. I've been using the Gummi-fledge and have always been happy with it, but you can always use something better.
Thanks for the info. The search is still on.
Thank,
Dan
Thank,
Dan
I seem to remember reading in excellence that the GTS vs. 997.2S suspension is not the same. It could be that the difference lies in the sport suspension equipped cars.
When I traded my 997.2S with PASM for my 11 GTS, also with PASM, it seemed that the GTS felt a bit tighter. Or maybe I wanted it to feel that way as my wallet had been lightened a good bit.
Interesting point that I forgot about. When I drove the S it had a low TPMS warning on the left rear. Since it was ~37deg I thought it was BS, but all the tires read in the low 30s. It could have definitely been true. I think I'll go take another look after work. Thanks!
I read and heard (on reviews) that GTS suspension is different from a Carrera S, this would have to be the case on the RWD cars due to the wider track. Most reviewers did say not to get S-PASM as it ruins the "perfectly" tuned GTS suspension. The general quote is:
"The wider track (by 2mm at the front and 32mm at the rear) has allowed some suspension reprofiling, so you get stiffer springs and anti-roll bars. The 19in rear tyres are wider too, at 305/30. Porsche claims the GTS is “more neutral” than the Carrera S."
Sounds like to me the discussion of the stiffer springs and larger anti-roll bars is related to the optional sport suspension, SPASM, that is available on the GTS coupes. Regarding not getting SPASM, I have it on my GTS and think it is superior to the regular PASM, not that there is anything wrong with the regular suspension. But SPASM gives the car a better look, plus better handling with the lower stance and slightly stiffer springs and anti-roll bars. Plus you get limited slip with the option. It is one of the best option values Porsche has.
I have the hardback Porsche GTS brochure and I can find no mention in it regarding any suspension difference in the GTS. You would think if there was a difference, they would talk about it like they do the other features of the GTS.
The GTS with non CL wheels were specced with 19" Carrera Sport wheels which are 0.5" wider front and rear compared to other available options such as the Turbo, classic and sport design wheel. While the fronts came with the same 235/35 tires, the rears came with 305/30 tires which have been specced with this wheel since the .2 launch for 2009.
My 2012 GTS cab's top squeaked badly too. I asked the service manager about it and he had one of his mechanics show me how to lube the top so it doesn't squeak. My Porsche is at my other house and I won't be able to look at the 1/2 used tube of lubricant they gave me for a while, but he said it cost about $65-70 for a tube (Porsche product).
