Delayed Throttle response
It seems like lately my throttle response is a bit slower than normal. I can press the gas pedal maybe a 1/4 to a 1/3 of an inch before I even get 100 RPM difference. I notice it on the way to work when I downshift from 4th to 3rd and later into second around the same corner I have been taking for 8 years. I rock the ball of my foot to do a little blip on the downshift and I have noticed that there is a difference on the throttle take up.
Any ideas?
Caesar
Any ideas?
Caesar
Any ideas?
Caesar
Any ideas?
Caesar
and no, you shdnt lose anything. only minor issue you may have is a PSM/PASM warning light which should clear itself within minutes during the first drive afterward.
The next time you start the car move the ignition key to "on" but do not start the engine. Then, floor the accelerator pedal several times. Finally, release the pedal and start the car normally. For many drive-by-wire cars that learn your driving style, this procedure will re-set the system.
Throttle wearing out? The throttle response of my '02 Boxster compared to my '03 Turbo is considerable. While the Turbo throttle is very responsive the Boxster throttle is not. The Boxster throttle doesn't seem to have lost any range. Full throttle still gets the engine to redline without any issue but I notice it takes more foot movement when I want to rev match when downshifting in the Boxster. I have only to think about touching the throttle in the Turbo and the revs increase. The Boxster I have to pay more attention in order to get the revs I want.
You can try recalibrating the E-Gas system. I don't think it will help but I hope I'm wrong. How to do this should be covered in the car's owner manual. For my cars with the key off turn it to the on position. Do not start the engine. Do not touch the gas pedal during the key on/key off phases. Leave the key on for 60 seconds. Turn the key off for IIRC 10 seconds. Then start the engine normally. Done.
