997.2 taillight removal
Old Jan 3, 2014 | 06:49 PM
gcurnew's Avatar
gcurnew
Default 997.2 taillight removal
Did a search but couldn't find a DIY for replacing 997.2 OEM tail lights. Is it as simple as removing the two torx screws, pulling the light out and disconnecting the wiring clip? Any tips/tricks for either the removal or re-install?
BTW, I'm replacing my OEM clear tails with the "standard" red lights with clear centres...not a fan of the clear lights...they look kinda cheap to me.
Old Jan 3, 2014 | 06:59 PM
Ynot's Avatar
Ynot
I would assume it's exactly like the 997.1, remove two screws and pull out.
Old Jan 3, 2014 | 08:50 PM
Wolfk's Avatar
Wolfk
Yes, remove the two torx, pull the tail lamp straight out in the aft direction. There is a tab in the forward corner, so do not twist the assembly, pull straight back. To release the electric plug, you have to depress the small latch with a small scribe or similar tool.
Old Jan 3, 2014 | 09:53 PM
Mumbles's Avatar
Mumbles
Just remember not to have any parts left over when your finished
Old Jan 3, 2014 | 10:30 PM
gcurnew's Avatar
gcurnew
Thanks for the confirmation that it's as simple as it appears...looking at the PET diagram and the light, there are just the two screws and a "tab" under the tapered end of the lens that keep it in place.
