Gas Mileage drop?
Old 11-24-2013, 10:57 PM
A.J. Merrifield
A.J. Merrifield's Avatar
Default Gas Mileage drop?
Looking for some thoughts from the group... Ever since I got the car a couple of months ago I've averaged right around 19.6 mpg... then in the last couple of days it suddenly dropped to 17.2 mpg. Ironically enough, that was during a long-distance drive in which I was feathering the throttle... Anyone have any ideas what could've caused the sudden drop?
Old 11-24-2013, 11:17 PM
Davidoconn
Davidoconn's Avatar
Hmmm. Bad gas? Not sure if you get the winter gas there. Makes a difference in some cars
Old 11-24-2013, 11:38 PM
PhilD
PhilD's Avatar
Winter gas blend maybe?
Old 11-25-2013, 12:11 AM
boolala
boolala's Avatar
Check your tire pressures esp in cold weather.
Old 11-25-2013, 01:23 AM
A.J. Merrifield
Yeah, tire pressure was the first thing I checked. I'm guessing it's probably bad/winter gas...
Old 11-25-2013, 09:41 AM
mxp
mxp's Avatar
i just had the same thing happen to me however over a period of 18 months, i was getting about 490km to a tank of gas, and before i knew it 18 months later i was struggling to get 330km to a tank
I had the dealer reset the adaptation on the PDK unit and all is well now, i managed 478km on my last tank
Old 11-26-2013, 10:36 AM
Little Green
Little Green's Avatar
My avg fuel consumption is 13.5 mpg. I get 19.8 on the highway above 85 MPH. It is worse in the wintertime. I am not sure how anyone gets more than 16 mpg in moderate city driving. I try being gentle with the gas but with stop and go traffic I still can't get much better than 13 and change.
Old 11-26-2013, 10:39 AM
FullThrottle64
FullThrottle64's Avatar
Originally Posted by Little Green
My avg fuel consumption is 13.5 mpg. [...] I try being gentle with the gas but with stop and go traffic I still can't get much better than 13 and change.
Really? I get ~17, even being fairly aggressive. Is it possible that the 3.8/6MT gets better mileage?
Old 11-26-2013, 10:41 AM
extanker
extanker's Avatar
i have no idea what mileage my po gets...nor do i care...its a car for fun
Old 11-26-2013, 10:53 AM
FullThrottle64
It's a good idea to at least roughly keep track of your fuel consumption; a sudden change can be a good early indicator of problems.
Old 11-26-2013, 02:52 PM
alexb76
alexb76's Avatar
Tire pressure is mostly the culprit, second, bad gas.
Old 11-26-2013, 03:22 PM
fskof
fskof's Avatar
also check if the air filter is clean.
Old 11-26-2013, 07:44 PM
997_Toronto
997_Toronto's Avatar
Thanks for adding your zero cents Just kiddin!
I've done a couple of long distance runs and the gas milage has been quite impressive. The last trip from Toronto to Indianapolis, 6th gear with cruise control gave me almost 550kms to the tank. Drop in gas milage after you've eliminated variables like dirty gas, etc. indicates a problem which should be triaged and a root cause identified or it'll get worse.
Old 11-27-2013, 09:52 AM
Little Green
My target range is 200 miles per tank. I rarely get there. Most of the time it's around 185 miles before my light comes on. But it's better than my 91 Grand Wagoneer. That thing gets 7 miles to the gallon on a good day with a good back wind and rolling down hill.
Old 11-27-2013, 02:54 PM
CarGuy21
CarGuy21's Avatar
Winter gas blend also with colder temps the engine management system stays in cold enrichment mode longer.
Quick Reply: Gas Mileage drop?
