TechArt Lowering Spring Question
I have an 09 C2S with regular PASM that I want to keep stock except that I hate the look of the big fender gaps, so I'm thinking about installing TechArt lowering springs. My car stays in the "normal" shock setting almost all the time. I'm interested in the opinions of anyone else who has done this mod. Are you happy with it? How much did it change the ride quality? Thanks.
^^ Do you get more scrub with PASM enabled when your bashing through the canyons, or tearing over the twisty mountain passes?
Any negatives, or is the baby drop (20mm?) all good / all the time?
usually springs dont make the car ride much harder, but stiffer shocks really make it seem alot harder, thats why when you engage your pasm shocks, it deffinately makes it feel hard
The 15 mm drop is for a car with Sport PASM because in stock form a car with Sport PASM is already 10 mm lower than a car with regular PASM. It's a 25 mm drop for a car with regular PASM and it's a 35 mm drop for a car without PASM. I confirmed this with SharkWerks.
This sounds about right. I also think that with lowering the car looks better with rear spacers otherwise the top of the tire is lost inside the wheel well. Plus you will need an alignment afterwards.
The 4/4S/Turbo (all with PASM) use different TechArt springs and my 997.1 4S (with PASM) definitely only lowered 15mm using the TechArt springs. TechArt Part Number 097.200.200.09
These are my measurements from the ground to bottom edge of wheel arch. This seems to be what people quote rather than the more accurate center of wheel to bottom of wheel arch.
Before:
Front Right - 67.6 cm 26 10/16"
Front Left - 67.3 cm 26 8/16"
Rear Right - 69.6 cm 27 8/16"
Rear Left - 69.5 cm 27 7/16"
After 2000 miles:
Front Right - 66.4 cm 26 6/16"
Front Left - 66.1 cm 26 1/16"
Rear Right - 68.0 cm 26 12/16"
Rear Left - 68.0 cm 26 12/16"
Drop:
Front Right - 1.2 cm
Front Left - 1.2 cm
Rear Right - 1.6 cm
Rear Left - 1.5 cm
John
Before:
After 2000 miles:
Drop:
Front Left - 1.2 cm
Rear Right - 1.6 cm
Rear Left - 1.5 cm
John
