GTS Alignment Specs
Anyone know if the alignment specs for a rear wheel drive GTS are the same as a regular Carrera S, or possibly the same as a C4S? I wasn't sure if the GTS would have different specs than a regular Carrera S because of wider rear track on the GTS.
Same.
Stock alignment with in spec for a sporty type of alignment for street would be around
Front
-1 camber per side
.02 to zero toe
Rear
-1.5 camber per side
.14 degree toe in per side
Front
-1 camber per side
.02 to zero toe
Rear
