Tire repair kits
Old Oct 20, 2013 | 10:52 PM
ATLDiver's Avatar
ATLDiver
Default Tire repair kits
As a new (to me) 997 owner, I'm putting together an essentials kit for my car. I have an emergency car kit, complete with mini compressor, flares, etc.
I want to ensure if I have a flat I can get to a tire place quickly. I know Porsche sells a repair kit that consists of plugs and some type of tire goop. Would a can of fix a flat work in place of this in a pinch? Roadside assistance is always an options but not always practical. Is the Porsche kit really the only way to go?
Old Oct 21, 2013 | 12:47 AM
Hella-Buggin''s Avatar
Hella-Buggin'
I believe there is a can of fix a flat in the trunk in case of a flat.
Old Oct 21, 2013 | 03:23 AM
Terry Adams's Avatar
Terry Adams
Veteran: Army
25 Year Member
I have carried the
http://www.griotsgarage.com/product/...ortby=ourPicks
Used it twice on the 997 TT and once on a friend's TT, each time without adding goop. With no spare, I consider it an absolute must.
Old Oct 21, 2013 | 08:29 AM
wheeler's Avatar
wheeler
Originally Posted by Terry Adams
I have carried the
So after you plug what do you do? I'm assuming at some point take to have it patched from the inside?
Old Oct 21, 2013 | 08:35 AM
wc11's Avatar
wc11
The OEM kit which has the compressor & can of Green goo should be in the frunk.
Old Oct 21, 2013 | 09:21 AM
targaC4S's Avatar
targaC4S
I was told that if you use the green goo you are suppose to replace the tire immediately. Any else know if this is true?
Old Oct 21, 2013 | 09:54 AM
Dubbin''s Avatar
Dubbin'
This:
http://www.dynaplug.com/buy.html
And a small 12V compressor will be your friend
Mark
Old Oct 21, 2013 | 10:01 AM
Smitten's Avatar
Smitten
That's partially true. Using the liquid sealant is a temporary fix, so you need to definitely service the tire immediately. Then, the type and location of the damage will determine if the tire can be repaired or must be replaced.
Old Oct 21, 2013 | 02:47 PM
USMC_DS1's Avatar
USMC_DS1
If you use goop do not remove the nail or screw from the puncher hole. Only remove the offending road debris when the tire is being patched.
Old Oct 21, 2013 | 03:25 PM
ATLDiver's Avatar
ATLDiver
Default Can these things be used with the tire/wheel on?
Originally Posted by Dubbin'
This:
Mark
My guess is no.
ETA....I watched the video on their website and called the company; honestly I never knew anything like this existed. I ordered the "Pro" model to go along with the compressor.
Old Oct 21, 2013 | 06:22 PM
okbarnett's Avatar
okbarnett
the instructions fro m tire mfg is that when you put the fix a flat into a tire, you should replace the tire, because the faf dissintegrates the rubber to make it seal the leak hole, and it also compromises the whole tire.
so when you bring the car to a dealer and want them to fix it, clean it out, etc, they will tell you they cant do anything unless you replace it.
PS, you should carry a string, plug kit with you.( leather composite strings, not plastic ones), a can of the glue and a reamer inserter tool. you can buy this a auto parts stores.
Old Oct 21, 2013 | 06:32 PM
USMC_DS1's Avatar
USMC_DS1
I use the Porsche spare tire kit when I head out of town.
Old Oct 21, 2013 | 10:39 PM
Terry Adams
Veteran: Army
25 Year Member
That is what I have heard, but I have driven thousands of miles till the plugged tire wore out, including some moderately aggressive canyon carving.
Old Oct 22, 2013 | 04:11 PM
BIG smoke's Avatar
BIG smoke
A patch can hold until it doesn't. I would be careful driving on a plugged tire at 2ookph.
My Subaru tires had a plug. My wife's MDX snow tire has a plug.
Do check your local provincial and state laws. Some allow plug, some require them to be vulcanized in the inside.
I have a plug kit in my car, green goo, and an air compressor, and of course, work gloves to absorb the blood.
Old Oct 22, 2013 | 04:40 PM
okbarnett's Avatar
okbarnett
I have had plugs in every car I own since the 70s, and never any problems
