Rear offset is for a wide body car and they will protrude past the fender. I wouldn't put them on my narrow body 2010 C2S.
Not true. Wide body 19x11 is a +40. I have also ran 19x11 +40 on Narrow body and it also works, but its pretty aggressive. I believe if your running a 10.5 on narrow body, it should be around 50-55
What's not true? OEM rear offset on the 997.1 C2 is 67mm so 40mm would extend 27mm (over an inch) more than stock - pretty far out in my opinion.
I guess its really personal preference. I personally think stock sits in too far. All I can tell you from personal experience that 19x11 et40 works on a 997 narrow body, but may be a tad too aggressive for some.
I like the look of them, but think they look to big, I would go for 19's. Is that a Photo-shop, they look so big it almost makes the car look higher off the ground IMO.
