Door speaker grille removal
In the process of detailing my car before delivery, the dealership used too much vinyl cleaner and the over-spray is "stuck" in the holes of the front speaker grille cover. To properly clean the cover, it's going to need to be washed.
I found the DIY to remove the entire door panel, but can the front speaker grille be removed by itself?
I had a similar and related task. I ended up removing the door panels. Actually they are not that difficult to remove.
Note: Many of the plastic covers/sections etc (on the door panel) are secured via plastic nubs/posts that are melted into position. Once you remove section (by heating the back posts with a soldering iron), these sections are not easily put back on; or reused. Fortunately I had purchased new replacement sections for my project. Strange, as I thought they would be screwed, clipped, or riveted into place. Nope! Thought i could reuse or sell the old pieces, but probably not.
I'm not 100% certain the speaker covers/sections are done this way, but I think so... I wouldn't pry too hard.
Hope this helps. Good luck.
.t
.t
.t
.t
Also you need to be really careful when cleaning too, as the speaker grills are coated with Porsche's rubberized paint, which when old scratches and peels very easily.
Wise choice. Maybe get some vinyl cleaner, spray it on some plastic and use some gentle products to see which one dissolves and removes the cleaner, then tackle the car.
I have a cracked speaker cover (the large one). no one would sell me just the cover so had to buy full panel - however used panel i bought has only the large speaker not the small so I need to swap the cover from new used panel to old one and just saw the "melted / plastic rivet" affixing method - did anyone on this thread successfully swap over a speaker cover? - I am thinking I could drill it out carfully like a rivet and then re-affix new with a wide head screw but not sure...
