Effects of running tires 5 pounds higher
Old 07-29-2013, 06:05 PM
jw1977
jw1977's Avatar
Do tire shops usually calibrate their gauges? I'm not sure where i can find someone who has a calibrated gauge, what do you guys usually compare to?
Old 07-29-2013, 06:10 PM
jsimon777
jsimon777's Avatar
I have mine set to 33/34 front and 37/38 rear. They seems to get up to 41-43 rear hot...Is that bad?
Old 07-29-2013, 09:32 PM
Dadio
Dadio's Avatar
So which temps are you using the first one listed or the second ? IE... 37 or 38 ? As for the hot temp that's consistant with my rear tires set at 38 cold in mid 80's Ambient temps.
Old 07-30-2013, 09:49 PM
jw1977
jw1977's Avatar
To stop the alarm from going off i have mine set at 33/39 per the TPMS but my Longacre guage and the 3 others i've tried reads 38/44.
Old 07-31-2013, 04:48 PM
Minok
Minok's Avatar
Remember that TPMS compensates the readings for temperature in deciding if its too low or too high.
Quick Reply: Effects of running tires 5 pounds higher
