Front Tire Wear?
I've noticed that mine are also wearing more n the outsides up front. This has increased since doing DE events so I'm assuming I need more camber up front. I'll check with my tech but I'm pretty sure I'm maxed out on the stock suspension. Time to consider a lower control arm upgrade.
What tires an pressures are you running?
Looking at a switch to Michelins
You absolutely need to have your alignment looked at when you throw in the Michelins or you'd be wasting money. You have abnormal tire wear. Next step up from P-zeros in the Michelin range would be the Pilot Sport 2. They are fantastic.
Nah, that's not really outside corner wear at all- track/autocross on a camber-challenged car will literally erode that corner and round it off- to the point where at this point in your tire's life, you'd see no tread pattern whatsoever between the first channel and the sidewall. Slightly too much toe out will give you wear like you're seeing. Get your alignment checked when you change your tires and you should be fine..
Aaron,
Just received your PM. Your front's are obviously not wearing normally. Best bet is to have your alignment checked, because even though it might feel like it's tracking properly, it's what you can't feel at this point that may be the culprit. Have it checked and post results! Good Luck!
Agree with the majority of comments - looks to be an alignment issue as the wear is not typical for fronts - toe problem or past pressure problem???. After your alignment and new tires, I suggest a good quality tire tread depth gauge (they're not expensive) and keep a log for a few months, maybe even a year or 18 mos depending on amount of driving. Measure your outer, middle, inner tread depth on all 4 tires with tire pressure and see if you find any anomalies building. If so, then you have other issues too such as suspension, bearings, wheels, etc. Very simple, easy, and quick way to know how those 4 points of contact are behaving.
Agree with the majority of comments - looks to be an alignment issue as the wear is not typical for fronts - toe problem or past pressure problem???. After your alignment and new tires, I suggest a good quality tire guage (they're not expensive) and keep a log for a few months, maybe even a year or 18 mos depending on amount of driving. Measure your outer, middle, inner tread depth on all 4 tires with tire pressure and see if you find any anomalies building. If so, then you have other issues too such as suspension, bearings, wheels, etc. Very simple, easy, and quick way to know how those 4 points of contact are behaving.
Only my first and latest Porsches have had uneven tire wear and both had alignment problems. The two that did not have tire problems were because I made the selling dealer do an alignment check before I would take delivery. My latest CPO had about 22K miles when I got it and my test drive on city streets did not show any tire problem. On a subsequent drive on a smooth road I could hear the tires literally howling. The car tracked straight and seemed to handle fine. Even though the outer tread of both front tires had plenty of depth, enough to pass the CPO, the insides were both more worn and feathered/cupped. The selling dealer paid for an alignment and two new front tires. I have never had uneven tire wear on a car that was properly aligned.
My front passenger tire is also wearing the same way, with the inside showing greater wear. My driver side is wearing evenly. I also currently have P Zero Rosso tires.
I'd like to know how your alignment goes, whether much adjustment was needed or not. I had a a full alignment done 3 years ago. Have never hit a curb or pot hole since and my car tracks straight and true. So I'm doubting if my wear is caused by the alignment. Wondering if my suspension might be showing some age, since my car is a 2006 model.
Here I thought I was the only **** retentive engineer who kept spreadsheets logging tread depth/wear across the face of the tire. A tip, measure the tires when new because the tread depth is not the same in all of the groves. For softer track tires, I also logged heat cycles and the durometer of the rubber across the tire.
To the OP - hope the alignment solves your issues. Please keep us informed if it does not do the trick.
any thoughts from those who have contributed earlier?
I really wish I had researched the PS2's more before buying because I didn't realize how "beefy" they are in appearance. I much prefer the slimmer profile tires. I swear the ride height has increased noticeably. They're not sufficiently broken in to comment on grip with spirited driving.
