Don't love the PSE tips
I've got a 997.2 c4s with the PSE exhaust. Are there different tips available and do the PSE ones come off easily? I've seen the nanocoated tips in the porsche parts/accessory catalog but its not clear if they're compatible with the PSE.
Miserable Old Bastard
Lots of aftermarket alternatives out there, for example Fabspeed, Maxspeed, and through dealers such as Sharkwerks. Tips are easy to remove and replace.
So, be careful. I think you need .2 PSE compatible tips. You can spend $1k on black ones that Porsche ships on the GTS
On the .2, you have dual exhaust pipes on each side running into the "sport tips". In contrast, the non PSE setup has pipes that the decorative tip splits into two.
I have also been looking for different tips, with the PSE on the .1 there are 2 inlet pipes and most aftermarket tips are single inlets and there doesn't seem to be any room for messing around in there, unfortunately...those fabspeed black chrome tips would be my choice...alas...
Newbies Hospitality Director
Suncoast Sport Tips
Are you referring to the tail pipes in the pic below? If so, no they do not fit PSE. See the description in the link.
Suncoast Sport Tips
Suncoast Sport Tips
Suncoast Sport Tips
