Best way to use iPhone to send sound to PCM2.1
even in my Smart, i have 3.5mm miniplug and i send my Pandora to speakers...
curious what the best option (please no FM modulators) to get sound from phone to PCM 2.1? or is FM modulation the only way? (i saw the factory "aux" setup is FM modulated)
i have 6CD changer, figured their might be a way to disconnect and then use that input somehow?
-riley
07 w/ NAV btw. and 6CD
-riley
typical solution is to ditch cd changer and instead you put in mobridge or similar unit that pretends to be cd changer but has ipod/iphone connectivity and Bluetooth.
where to buy mobridge? that seems best for me... can i connect in frunk, or have to remove the pcm 2.1 and plug in back... i would hope i can unplug 6CD and plug into frunk..
I had moBridge in my 07 4S and it worked very well. Best bluetooth system I've used in any car to date. The installation took several hours at my Porsche dealer, so it was expensive. I think they mounted it behind the PCM somewhere.
http://www.mobridge.us/distributors
