Alignment help
Front Toe: +5'
Front Camber: -3/4 deg each side
Rear Toe: +20'
Rear Camber: -1.5 deg each side
After recently re-installing my Damptronics due to getting them repaired, I had another alignment and corner balance done, in Canada. I asked the shop to set the alignment the same as before. The alignment info provided to me is:
Front left toe IN: -1.00 mm
Front right toe IN: -1.00 mm
Rear left toe IN: 2mm
Rear right toe IN: 2mm
I wasn't given any camber info.
I don't know how to compare the mm settings with degrees/minutes.
Can someone explain if the new alignment (at least Toe IN) is anywhere near the previous settings, as it appears I now have toe out, which I would think would make the car not track in a straight line too well (although it isn't noticeably bad so far).
BTW, the new corner balance looks fine. I don't track my car, but like to drive enthusiastically and would like to continue getting the good tire wear I've experienced so far.
