My 05 997S smoke pouring out the exhaust, advise needed
I decided to sell my 05 997S Tiptronic with 39k miles to pay for my new winery. I had a buyer that was long distance, he wanted me to get a PPI so he scheduled me to bring it in to a place. The rear tires were bad so I had it towed in, after it arrived, apparently the tow truck driver said it was smoking and so I called they told me it was smoking and the CEL was on. I don't drive the car much at all but I pull out of the garage and back in daily to do work, I also pulled it out that morning and there was no smoke, no sign of any problem whatsoever, now instead of having the car sold, I have a car with a big engine problem. The shop is telling me the oil is cloudy and there is probably coolant in it and when the spark plug was removed, oil came out. They are saying they need to pull the engine and open it up to know what's wrong with it. They are not a Porsche shop, so I'm thinking it's probably best to take it to the Porsche dealer to at least get a second opinion, because right off the bat they told me it could be the oil separator and it would be much less than opening up the engine...
Does anyone have any advice or opinions? I would greatly appreciate it because this is the craziest thing that has ever happened to me with a car...
Thanks!
Thanks!
I don't have technical advice, but I'd definitely get a second EXPERT opinion.
Thanks!
Thanks!
re: the item above in bold - i know the spark plug tube o-rings can leak. i dont know if this also causes smoking but could be the source of the issue observed. i'm not sure what is involved with replacing them.
i would get a dealer opinon but would def take it to a REPUTABLE porsche indy for 2nd opinion, etc.
Smoke out of both sets of pipes is typically related to AOS. Smoke out of the driver side exhaust pipes and associated wet plugs on the passenger side (bank 2) may be an indicator of a scored cylinder... due to cooling issues with bank #2. +1 on getting a 2nd opinion from reputable Indy and/or p-dealer. Have them bore scope the cylinder which the wet plug came out off... GL and let us know the outcome.
Air Oil Seperator
Mine wanted to do a $6,000 head job(no jokes) for a leaky plate gasket that cost $250 to fix...
It's not just Porsche... our Toyota dealer asked $3K to replace my son's ABS module. We DIY the project instead using a used module from a wrecked truck. It costed us $120 for the part and 20 minutes to remove 3-4 bolts. Still working well a year later.
Here's a write up if you want to tackle it. Replacement part. http://www.pelicanparts.com/techarti..._Separator.htm
