Loud driver side ventilated seat?
Just bought a '12 997 C2S Cab w/1400 miles, had it delivered Monday. Really enjoying the car so far. Testing out everything to make a list of any issues to have service look at. So far a bad rattling heat/AC vent and a squeaky convertible top that from what I read from searching here shouldn't be a problem getting fixed under warranty.
One issue that I can't diagnose is a problem with the driver's side ventilated seat. When activating the passenger side it seems to operate normally and silently. However when turning on the driver's side I hear a "psssssst" air sound coming from behind the seat, fairly loud too. Couldn't dig up anything on the search here about a similar problem. Anyone have any ideas? Hose from the air pump to the seat leaking?
Not sure if they're the same as in your car but the vented seats in my 09' do have some noticeably normal sound when the vents are turned on (especially at maxed vent), however the noise level observed from both passenger and driver sides are the same...that being said, if you do notice the driver side sounding louder than norm, take it to the dealer and get checked anything abnormal should be under warranty.
i have a '09 C2 which i bought last summer as a CPO, my driver's seat ventilation is a bit loud as well. Has not really bothered me enough to bring the car in for just that. I'm still covered by original factory warranty for another month as well.
If you do have the dealer look at it, please post a follow-up.
John
John
The only issues I've had from my ventilation is you can feel a bit of vibration from the fans when on the highest setting.
if there is a noticeable hissing sound you should see if the system is clogged or has debris in it. Its just a fan that sucks air through the holes in the seat leather and vents out the back. If a large amount of the holes are clogged (or you are wearing leather pants and jacket where the suction cannot pull air through all the holes) - then you may get some hissing.
Wear natural fibers to get the best results from the ventilation.
Sounds like a small hole or slightly loose bracket in the plastic tube that shoots the air into the seat. Since you have warranty, add it to the list for Dealer to look at it.
The ventilated seats don't shoot air into the seat. They suck air out of the seat - pull it from your body through the seat and vent it out the back, where the system is mounted.
