New track video, enjoy! :)
Yup, it was a GTR, I found following a faster car was a great way to get faster. Although at one point I did get overly zealous and tried to keep up with a GT3RS, I had a almost spin at before turn 4 and finally decided to back off a little for the rest of the day
I wont be at Buttonwillow, my fiance and I are planning a wedding this summer, so DE's will be on the back burner until at least Aug. Maybe I can sneak out and do a DE at THill since its less than an hour from my house lol. I do mean the SuperSport, for me, a proper alignment and PSI made a a huge difference on the track.
Chris
here comes the whole story, will be a tad long but bear with me.
Let's start with the end: In lap 4 of session two I heard a thumb, thumb, thumb from my right rear well, and I thought that I had a flat tire. What really made this noise was a separated piece of threat, hitting the inner wheel liner.
So how did this happen? And I can tell you that every single step in this conga-line of mistakes is due to my own negligence or stupidity, no-one else to blame here but myself.
As previously said, for the last 5 years I was tracking a Boxster S with fully adjustable suspension (PSS9 and adjustable sway bars) and DOT-R tires. The car was behaving super-neutral, and would when pushed hard slightly oversteer.
Mistake 1: Tire pressure:
My DOT-R tires had their sweet spot at 38 (hot) and usually gained 6 ~ 8 degrees during a session. But in the 997 I actually was on street tires and started with 34/32 cold which went to 40+ at the end of a session when the ambient temp was cold, so for session 2 I dropped the pressure down to 30/28 cold (aiming for 38 PSI). Great for my DOT-R but I was on street tires (RE050) which like like higher pressures...
Mistake 2: the tire pressure gauge
When packing for the track I couldn't find my original gauge and picked a gauge that was lying somewhere in my garage, turned out that this gauge was reporting pressure too high by 3 PSI, so in reality I started with 27/25 cold (waaaaaay too low).
Yes, Yes why didn't I look at the TPMS? My 986 didn't have one, so I forgot about it.
Mistake 3: A 997 is not a 986
More weight overall and much more weight in the rear. I was sliding in the rear much more than with the Box and the (under inflated) tires really didn't like it
OK, at least I took it easy the first two laps (like usual) to warm up the tires, but I never got the tires to full pressure and there went the whole ballgame ....
OK, new tires (Michelin SS) are ordered, and the old ones were almost ready for replacement, so no biggie here.
What really hurt that I was so looking forward to 2 track days which turned into 1 1/2 sessions. But then again, track days are almost like trips to a strip club. You leave with your wallet much lighter and there is nothing tangible you take back with you, except pleasant memories ;-)
OK, many lessons learned, and I will be much better prepared next time (Laguna-Seca on May 19)
Hey Chris & Magnus!
I'm running MPSS as well and had them set at 32/37 cold. I'm on a c2s and after a run they were up to 40/44 hot. I felt like they were starting to loose some grip. I might back them down a bit to start with next time and see how high they get. Ideally, you want to stay under 40 correct?
