Zunsport Grilles
#31
Do you know how they are afixed to the bumper behind the slats on the 997.1? I didn't want to drill holes.
#32
Anyone else with a 997.1 wnat to chime in?
#34
The holes are for pins on the screens that fit in the hole.
I was nervous to do it... but I am happy with the result. I think zip ties would look much worse IMHO.
Sullivas: The screens do not "go behind the slats" on the sides. There are two small screens that are placed in each of the openings (one above and one below the slat).
Keep in mind... my car is a daily driver (2006 C2S with close to 40k miles on it)... so I am more willing to drill to secure a protective screen than others might be.
#37
Just installed mine. I didn't like the look of the grilles in front of the air guides, so I decided to install them behind
Yes, you need to take the bumper off for that, took my two hours for the whole job.
BTW: If anyone needs a 15% off code here it is: ZU041510
#38
I don't see the ZunSport logo on your grills that are shown on the website. Have you removed it, or is it an optional application?
As a not DIY guy, what do you think it would cost to have a body shop remove the bumper cover so that the grills could be installed behind the slats? I think the 3D look is better than mounted in front of the slats.
#39
#40
[QUOTE=fbfisher;10422116]I don't see the ZunSport logo on your grills that are shown on the website. Have you removed it, or is it an optional application?
I did not get the logo either - actually don't see it any of the pictures.
#41
Mine did not have the logo either. I think there is option to buy all together and that might save you money called the "front grill set" I believe it has all three. 225 pounds before discount.
#42
Mine was about 199 pound sterling or about $295 US$ for full set L, R and Center. my kit did come with bolt-on badge as well. Installed this evening took about 10 min.
#43
Did you order one part number for all three parts, or did you order the center and sides under different part numbers (i.e., two items in your check out basket, or one)? Thanks!
#44
Order Details
Items
1 x ZPR32705 - Porsche Carrera 997.2 + C4S - Front Grille Set (Black Finish) @ £223.54 = £223.54
Total Price: £223.54
Z U N S P O R T
