Alarm randomly going off
In the last several weeks, my alarm has triggered 3-4 times with zero contact with the car. 2 times it was right outside my office window and I've been able to disarm right from my desk. A third time it was going off after taking my daughter into daycare. Any thoughts on what the culprit could be? New battery put into the car probably 2+ months ago now. Possibly related? Appreciate any thoughts everyone might have. Thanks!!
This has happened to me too and I believe I read in this forum that it has happened to others. One thing I saw had to do with microwave ovens. I think I can tie mine to that since it seems to only happen in my garage and the microwave was used around the same time. As with your event, nothing messing with the car.
the car sits right outside my office window and i know nothing touched or was even close to my car this morning when it went off. this same scenario happened at my office a week or two ago. simply going off on it's own.
RSA,
I had the same issue but sometimes hours after I had locked the car. For now I do a double tap on the lock door and it does not set the interior sensor, just locks the car and alarms it. Click on it, then click again a half second later. You typically get a double flash for the alarm being set. If you double click it the right way the lower lights will stay on for about 2 seconds indicating the car is locked and alarmed but the interior sensor is turned off. Hope that makes sense
Caesar
Caesar
Last edited by Little Green; 02-25-2013 at 03:29 PM. Reason: I was incorrect and fixed my post. Thanks to Brennan for the correction
RSA,
I had the same issue but sometimes hours after I had locked the car. For now I do a double tap on the lock door and it does not set the alarm, just locks the car. Click on it, then click again a half second later. You typically get a double flash for the alarm being set. If you double click it the right way the lower lights will stay on for about 2 seconds indicating the car is locked but not alarmed. Hope that makes sense
Caesar
Caesar
Deactivating the passenger compartment monitoring system for one locking process
If a person or animal remains in the car while it is locked, the passenger compartment monitoring system must be switched off. Quickly lock car twice. The doors are locked but can be opened from the inside
1. Pull inner door handle once to unlock door lock.
2. Pull inner door handle again to open door.
Note
Inform any person remaining in the car that the alarm system will be triggered if the door is opened.
I had this issue with another car because water had gotten into the switch of the trunk due to heavy blowing rains. Assuming that that is not the issue...
as others have said, the alarm has an interior monitoring system that looks for intrusion inside the car - say someone breaks a window and reaches in or reaches in through an open window or sunroof. I think that system uses some sort of radio frequency of course, and transmitters of some types can confuse the system into thinking there is someone entering the car through an opening.
Try disabling that interior monitoring, as mentioned. It does sound like a funny thing if having a microwave within sight of the locked car can trigger the alarm, but that frequency range is probably close to the alarm systems interior space monitoring system.
locked with the quick double-tap lock this morning (single long light flash). hopefully, this is going to cure the alarm issue as i really don't need the interior sensor with windows up and doors locked. thanks again.
I had a similar problem with my 996. I used the Durametric reader to see what was going on, and it had several faults from the radio. I suspected that the radio thought it was being stolen, and told the computer to raise a fuss.
just to keep everyone up to date - as long as i double tap, i've had no issues. i forgot and single locked at our day care the other day and when i came out the lights were flashing. i assume the alarm had already stopped sounding. no problems again if i double tap.
There is a motion sensor in the center console which often times breaks by frequent opening and closing of compartment. I found the easiest fix was just double clicking the remote just as you are doing.
