Leatherique Rejuvenator
Guys,
I think a few of you have recommended the Leatherique Rejuvenator for leather upholstery in our cars. I picked some up from AutoGeek recently and used this week. I am utterly amazed at how incredible the car looks now. My leather isn't dry or scorn in any way but the Leatherique took the look and feel to an all new level. I would even recommend it for new cars to soften and protect. Using the Leatherique on the Leather and 303 on the Vinyl makes and unbeatable combination. It's expensive but works unquestionably well.
BTW I also used the stuff on one of my wifes old Coach purses and she was amazed at how nice it turned out. I think I got out of buying a new black Coach. Just say'n guys....easy to justify this purchase if you catch my drift.
+1 I use the stuff on leather couches as well and it's night and day.
It may be my imagination, but I swear it even makes new crappy leather feel like quality. Used to have a 1st gen Mercedes ML years ago, the one they skimped everything on, after Leatherique you'd think the hides came from England.
I have used Leatherique and 1Z. For quick detailing 1Z is the best product I have used. It leaves a clean matte finish and digs deep to leave leather looking brand new. It also seems to tighten up loose leather.
I completely agree; it is the best. I've used it for many years now as a once a year application. I also use Girot's leather care in between Leatherique applications. Might sound a bit excessive but with a cab and the CA sun, the combo keeps my interior in excellent condition.
(from an 996 owner)
After spending some time recently reading up about leather types when I needed to get a sofa couch re-covered, I found out most automotive seat leathers are coated with plastic coating to provide wear and UV protection, and "leather" treatment does not actually penetrate through the plastic coating to serve the purpose of supplying the leather with the various compounds to keep the leather soft etc.
That said I'm sure the leather used in some high end cars are of the type that does not have the plastic coating, and these leather surfaces DO very much require the good care to keep the surface maintained.
The question then is can the seats in the 997 take advantage of the expensive Leatherique Rejuvenator to actually serve its' intended purpose?
For the record I have bought the Leatherique cleaner and rejuvenator, and have used them on the leather seat of my DD (an Accord Coupe) and the leather sport seat on my 996, For the 996, the left shoulder bolster of the driver side was very dried out and showed hairline surface cracks when I bought the car in 2011, I used the Leatherique and Lexol products on this area, and the leather did soften up somewhat which I expected it to since the surface cracks would allow the liquid to reach the leather fiber under any surface coating.
As for the rest of the leather seating area on the front seats, I saw no difference before and after the treatment with either Letherique or Lexol products, other than cleaning the surface of some surface grime and to prevent further deterioration of the leather surface. I also understand the rear seats in my car are not even real leather, is that correct?
You could try that and see if it works. Swissvax makes top stuff.
http://www.swissvax.us/merchant.mvc?...e=LEATHER-CARE
(from an 996 owner)
It's really not a pain in the *** to use. It does take a little longer then your typical cleaner/conditioner but you will never get the results with anything like what you get with Leatherique. This is the best stuff on the market. Go talk to any restoration shop they will all agree!
Ive used this in older cars where the leather has hardened and feels like cardboard. It definitely does wonders and is pretty awesome stuff. If your car isnt old or hasnt been exposed to the elements, you can get by on Zaino but if your leather has lost its suppleness, its definitely the best out there.
Its a bit tedious applying it as there is a long wait time and you need to do it on a hot day...
