On my 997, my salesman knows me pretty well so he tossed me the keys and asked me to get back before they closed for the day (6 hours later).
awesome.
My salesman was only on the job for a week. I let him know ahead of time that we would need to drive for at leat 10 minutes (to get the oil temp up) before the real part of the test drive would commence. He had a big smile. I bought the car two days later.
I was told by a PCA instructor that 911's have always had a weak first gear. He recommended shifting earlier, around 3,000 RPM to 2nd and let it rip from there on. True or false, not sure.
Also, many 911's are owned and driven infrequently by non-enthusiasts, typically older professional men who buy automatics and never drive enthusiastically. It sounds oxymoronic to own a 911 and not enjoy the power and handling, but it is factual.
Not sure how relevant this is, but what are the shift points for a PDK in sport and sport+ mode? You have to figure these are pretty safe if used in a 6-speed.
I think in sport and sport + the transmission shifts at about 7200 rpm on my GTS with full throttle. At that rpm I tend not to be looking at the tach. If just driving in sport it depends on what you are doing with the car. If the computer senses that you are having fun it will hold the gears longer. I believe if I am not pushing the car shifts at around 3k.
Funny back in the day when I sold my Air-cooled 911 I warmed it up prior to the customer coming, I started the drive and purposely drove it hard before I let the buyer take over, I wanted him to feel what the car could do and not be worried about babying it. I did not redline it the whole time, but drove it enthusiastically.
On my recent test drive before I bought my car I did not redline it, but I certainly hit 6K a few times.
Odd Seller
Now to answer your original question I actually rarely, if ever, beat on my cars, but on a test drive it should be expected.
Interesting. That's the first I have heard that, but it matches my impression of my recently purchased 997.1S. It's a though first gear is just what you gotta go through to get to second, which is where I feel the car really comes to life. No complaints though.
My service guy recommended not letting rpms fall too far below 3k at any speed in any gear. And certainly not cruising and maintaining rpms below 3k. So in just normal driving after car is warm I don't shift before 4k rpm.
. Where the two lines intersect on the graph, that's the sweet spot. Try keeping the car within the range of the two peaks. That is where torque and HP intersect giving you the best overall performance. Shift at a point where the HP curve is at its max, this way when you shift gears and the rpm drops, you will now be accelerating again within the maximum torque range giving you the best acceleration. If you try shifting at redline you will see that in this range, torque and HP are declining, not giving you the performance you think that you should have.
Very informative post!
This does sound correct!
I have a question though, how come when Putting foot flat in a PDK it runs till red line every gear as apposed to what you are suggesting ?
Why does is the gearbox not programmed to change at the points where the car would give maximum acceleration ?
It's about the area under the curves. So, although the point of intersection is optimum, the goal is to stay in the rev range that optimizes area under the curve.
As far as first gear being weak. This sounds like hog wash. That said the first to second shift is the most challenging and demanding on the clutch and transmission synchronizers because it has the greatest delta in rpm. But that doesn't mean it's weak.
The car doesn't come to life in 2nd more than 1st. The engine comes to life when it 'gets on the cam', which is a way of saying that, given the engine specs (oversquare) and the cam profile, the engine is noticiably livelier above 3,000 RPM and particularly above 4,000 RPM... and vario cam makes life down lower more bearable, but this is still a peaky engine.
If you want to feel the max aggressiveness, requiring your fast reflexes, when you're in 1st gear and wooshing past 4500 RPM, that is the fastest pace at which the tack needle will move, and redline is coming NOW... and then 2nd gear is second fastest, thanks to the peaky flat 6 and the wonders of gear reduction.
What you feel or miss in engines like this is the tractor-pull feel of torque, stroker engines, displacement, etc. Your 'feel' is fooling you, because these cars run in the 4's to 60, and there are a lot of cars that feel faster (thanks torque!) off the line, but they ain't.
