transmission
On the verge of getting a turbo and not sure if I want a traditional 6 speed or PDK. Car will be driven daily and tracked once in a while. Are the PDK transmissions more delicate or fragile? I understand that shifts are naturally faster but is that the only advantage? Can you guys help on the little dilemma I'm having? Thanks.
If you're going with the 997.2 Turbo S I believe it is available only with PDK.
Or get the manual like I would for the fun of rowing thru those gears.
