Flat Tire
Flat Tire
Started the new year off with a bang.
I got a flat in my rear right tire yesterday. I have the air compressor that comes with all 997.2's and the tire sealant.
I hadn't used the air compressor before. So, before adding any tire sealant I connected the air compressor to the flat tire and turned it on. It started to inflate the tire, but it just stopped working after about a minute of use. I checked that the power connection was good, etc. but no matter what I did I could get the compressor to turn back on.
So, since I couldn't get the compressor to work I didn't put any of the tire sealant in the flat tire.
I called roadside assistance and had them take my car to the dealer. There was no visible issue with the tire. So, I don't no if there is something wrong with the valve stem or the wheel and I had them flat bed my car to the dealer.
However, the service department at the dealer is closed today and I am without a car.
A couple of questions about this. Has your air compressor failed? Also, has anybody tried using fix a flat and tire sealant cans that don't require an aircompressor?
I certainly don't have a warm and fuzzy feeling about driving my car outside of town where it may take forever for roadside assistance and I am stranded. I've seen some threads about spare tire options, but I am interested in what other solutions others may have come up with.
Thanks,
Thanks,
Thanks,
Thanks,
The compressor that came with my Cayman failed after about a minute. Likewise, a friend's for his '07 Carrera failed in the same time. I went out and bought a better inflator/ compressor even though my dealer replaced mine under warranty. Remember if you use the sealant that comes with the vehicle you may have to then replace the tire pressure sensor on that wheel. Oh where, oh where have the spare tires gone. Of course even if you got a space saver spare and inflated it to replace the flat where would you put the flat tire/wheel if it were a rear .... maybe behind the front seats.
Yeah, my back seats are used by my boys that ride along with me. I had a 986 with a spare tire and this episode hasn't endeared me to driving on the edge without one. Not fun to say the least. Just glad that the weather was decent, etc as I had my two boys with me.
I plugged the compressor into the receptacle on the passenger side foot area. I didn't see anything in the manual about using the cig-lighter recetacle though.
You might also want to buy one of these 12v compressors. $50 at Amazon and highly recommended. Dave
http://www.viaircorp.com/85P.html
Good chance that you blew the fuse. In mine it appears to be Row A F8. I've attached a pdf I made of the fuse guide which I find easier to read than the factory supplied microprint fuse guide. Good luck!
Make sure to use the cigarette lighter outlet for the air compressor as it has the higher wattage rating. The passenger side outlet at the foot well will typically blow out it's fuse if you try to use it to power the air compressor.
I've used fix-a-flat once in an emergency but will not likely do it again. Sticky gunk sprayed out from the puncture hole all over my inner wheel well. It was a real mess to clean up. I've since gone with the Porsche Spare Tire kit. http://www.suncoastparts.com/product//997STK.html BTW, the rear tire will fit in the rear seat. From what I understand the p-car compressor is not very "capable", intended for emergency light duty use only, and should only be used with the wheel off the ground if possible. I know... hard to do since Porsche does not include a jack with the car. Hint... get an inexpensive scissor jack or the Spare Tire Kit which includes the jack. Definitely one area that could use some improvement and consideration by Porsche. BTW, I have AAA Premier, CC's, etc but nothing beats a spare tire to get you back on the road quickly.
It's referenced in the manual in at least two places -
The flat tire section (p 215 on my 09 manual) says to use the cig lighter but it isn't highlighted. It is also repeated in the section of the Electrical System and the section on the Cig Lighter. Search is so easy when you have the pdf version of the manual
Yeah, I'll have to invest in a jack, a better air compressor, and good road side assistance service, but 1K is a bit much for a spare tire. Maybe I can find one on Ebay, etc.
Thanks for the help.
