Clutch bleeding question
Old Dec 27, 2012 | 11:16 AM
niner niner seven's Avatar
niner niner seven
Default Clutch bleeding question
When bleeding the clutch on a 997, why is it necessary to fully depress the clutch pedal?
When I just bled the clutch, I had about 8 psi pressure on the brake fluid reservoir from the power bleeder when opening the clutch bleeder valve. Upon opening the clutch valve, fluid readily flowed and I thought the line was flushed. Because of this I did not deem it necessary to depress the clutch. Will there be any significant problems if the clutch pedal was not depressed during the clutch flush? Thank you.
Old Dec 27, 2012 | 12:23 PM
Fred R. C4S's Avatar
Fred R. C4S
Short answer...no. That's the beauty of using a power bleeder. You can go up to 15 psi, but that's it.
Old Dec 27, 2012 | 08:42 PM
CORSASCHNELL's Avatar
CORSASCHNELL
I believe by depressing the clutch pedal you get all the old stuff out of the system. I would do it just in case since I don't want any contaminants from the old fluid mixed in with the new.
Old Dec 29, 2012 | 01:13 PM
niner niner seven
ok thanks all for responses.
Old Dec 29, 2012 | 11:43 PM
cv997's Avatar
cv997
How/where did you access the valve to bleed the clutch? Did it require any special tools? I've heard that Porsche manufactures a tool specifically for this.
Old Dec 31, 2012 | 01:19 PM
sullivas's Avatar
sullivas
I used a socket to crack the bleeder open, then finger tight, put the hose on, twist open with fingers during bleed, twist closed, remove hose, then tighten with socket. Worked fine.
Old Dec 31, 2012 | 02:17 PM
shadesogreen's Avatar
shadesogreen
Since the bleeder is hard to access I found this to work the best. First of course I remove the bleeder cap, then I put the tubing over the bleeder and slide a stubby ratcheting flex head gear wrench over the tubing and loosen the bleeder. Reverse the wrench, tighten the bleeder and remove the tubing. Simple and no mess.
Old Jan 1, 2013 | 03:20 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Check out my pictures...
https://rennlist.com/forums/997-foru...fluid-job.html
Old Jan 1, 2013 | 08:46 PM
997_rich's Avatar
997_rich
I've been thinking about cutting the side of a tall 9mm(or is it 8mm) socket so I can use a long extension and also have a hose on the bleeder. Last time I used a wrench I cut down to about 2" long.
What's the bleeder size again? 8, 9 or 10mm?
Old Jan 1, 2013 | 10:51 PM
Lvt19672's Avatar
Lvt19672
This might be a dumb question, but why is it necessary to bleed the clutch?
Old Jan 2, 2013 | 09:09 AM
997_rich's Avatar
997_rich
The fluid deteriorates over time and loses it's effectiveness. It deteriorates with heat, takes on water and becomes more compressible (mushy connection between pedal and clutch). Also, the hoses, cylinders etc do give off particulates as they wear, when you change the fluid you clean the whole system.
