First DIY: Mesh Radiator Protector
#33
Dave, did you end up doing the center portion of the bumper too? If so can you share some details. I sort of think it would complete the look, as opposed to just doing the 2 side openings.... IMHO .
#34
The Zunsport grills for the 997.2 only install in front of the louvers which completely change the look of the car (for the worse). It looks like the ones for 997.1 installed behind the louvers. Anyone know if the 997.1 grilles fit a 997.2?
#35
#36
I'd like to see some type of grille that can be installed & removed from the front without having to remove the bumper.
The grilles will eliminated the leaves and cigarette butts yes, but I still go in there and the end of the year with a shop wac and hose the clear out the gravel.
#38
#40
David, try these...
http://images.autotrader.com/scaler/..._A.562x421.jpg
http://images.autotrader.com/scaler/..._A.565x376.jpg
Nover mind, I see you wanted pics w/o the center grill. Personally, I like having the continuity of having all inlets covered. Also keeps debris out that can find its way to your radiators that may be difficult to clean out with the grills in place. Just a thought...
#41
Sure, here you go. As you can see, I have my plate mounted on the tow hook which sort of 'hides' the fact that there's no mesh. Still, even without the tow hook mount, I wouldn't bother covering the center section. Also note that a significant amount of air enters the center and is redirected to the outer radiators. No point in adding in more resistance to flow.
BTW, I'm also in MV so we are neighbors (and there's one other who drives a Cayman). dave
#42
David, try these...
Btw, parked next to a gorgeous brown GTS yesterday...I'm sure glad that I didn't see your beauty before locating my soon-to-be C4S or I'd be eating beans and tortillas for a while.
#43
I'm going to start with just the side grills but I need to purchase a solution for install as I have two left thumbs and I'm picking my C4S up in Virginia and driving home (the long way!) and want the protectors installed prior to driving home. Fwiw, I prefer a behind the slat solution...
I'll be in MV for just another couple weeks (lived here 5 years...in Marin for 20+...I'm out on Bigelow just off of W. Blithedale) but now an emptynester and moving to a house on Inverness Ridge. I'd love to get together when things settle down and I bring the C4S home...that should be around 10/23 unless I get lost in the Rockies...thanks again!
#44
Thanks Dave,
I completed the screen install today via the DIY route. Done in a snap took about 40 minutes and for $43. I used the Small Diamond Mesh in Glass Black from Customcargrills.com and am thrilled with the results.
Frank
Frank
