driving you Porsche in winter
I have had really good luck with the waterless car wash....spray on, wipe, buff out...all in the comfort of my garage....also leaves good protection and water beads and rolls off...it is able to cut through pretty tough grime and I haven't had any scratches from using it...
hi guys, just wanted to get your opinion on driving a 997 C2 in winter with winter tires???...looks like most of you have a C4S so I wasn't sure if you have experience using a C2 in bad weather?
I live in Northern VA/DC metro area. Probably will drive 200-300 miles per week--mainly highway.
Thanks,
Mike
Thanks,
Mike
It's fine. I run with Bridgestone RE970 AS. Great tire. Dedicated winter tires are of course better when it gets really bad, but down there you're gonna see slush and chilly weather mostly. When you get hit by a blizzard all traffic stops anyhow. I've driven rear drivers up here for the past 20 years, never a problem. All about the tires.
I'm from Montreal originally. 996 carrera was best 2-wheel drive car I've driven in winter. Yours should be better. Pm for a phone number if you want details.
I took my car out in a snow storm (on winter tires) once as a test. It really did very well. I was passing by stuck cars left and right. And I got up the hill to my street with zero problems!
Also note that winter tires don't just help in snow and/or ice. They also don't become hockey pucks when the temperature goes down. Our summer tires' characteristics change once the temperature gets into the 30s F. They become much less effective at keeping you on the road. Winter tires are made to grip at lower temperatures.
I've been changing into winter shoes around Thanksgiving here in NJ. In NoVA I assume you could wait until mid-December or so. But if you're putting in 200-300 miles a week, you should definitely switch once the weather gets cold.
This is a great thread, am planning to drive my (newly purchased) 2007 997.1 CS2 in the winter in downtown Toronto. I've got a spare set of rims and plan on putting winter tires to ensure better grip & stability.
I've been looking for almost a month now but don't seem to see a lot of winter tire options for the specific rim size. I have 2 questions:
1. What are some winter tires that you guys have used and are happy with?
2. Is it cheaper to buy tires in the US and bring them over instead of buying them in Canada (Toronto)?
The conventional wisdom of the board seems to be that C2 is at least as good as any other 2-wheel drive car AS LONG AS YOU'RE ON WINTER TIRES. The fact that the weight is over the drive wheels helps you.
