Paddle shifters on multi function steering wheel
Does anyone know if I can install paddle shifters on a multifunctional steering wheel?
I see that Suncoast has a kit to replace a standard wheel with the up/down switches with one with paddles shifters. I was wondering if there's an option for the multifunction wheel as well?
If that doesn't work, can I "downgrade" a multifunctional steering wheel to a standard with paddles?
Was doing some research on this as well and found this.
http://www.sharkwerks.com/products.php?pid=274
So appears the answer to the question is Yes.
Has anyone had these installed? Any pros/cons of adding the shifters to the MFSW? I like the MFSW but would definitely like to have paddles for track days.
I looked into the Techart conversion and then went with the Factory paddle wheel.
