@@@@Space Saver Alternative@@@@@
Just browsing and saw the space saver tire kit would run you up to $1000 dollars waaaay to much in my book until my wife pulled up with her car a 2005 Touareg and presto,Saw some on ebay for $300 for the kit hope this helps.
Thanks for posting... that is very interesting. Do you have a C2 or C2S? Could not tell by the pic so I just want to make sure it will fit the larger C2S brake calipers. I assume it is limited to 50 mph/80 km speed. Does it work on the rear as well? have you road test it?
Kerlow....do you have it secured in the trunk or it just fits snugly? What do you do with the flat? I notice you have a coupe (observant huh).....will it fit in your car after the switch?
Thanks in advance.
Tom
Thanks in advance.
Tom
What's the inflated OD (outside diameter)? Or what's the circumference?
As a front tire I don't think it will matter, but for the rear don't want to overheat the diff/trans oil with two badly mismatched tires should I need to continue some distance at speed
But great find!
But great find!
Hi Tom when the spare is in the trunk I have 6"+ of space on the side,as far as securing it I have not tackled that problem yet,i have seen the DIY thou and it looks pretty straight forward.i will be using it on long trips only cause the spare weights 70lbs easily.
But great find!
But great find!
The spare tire kit from suncoastparts includes a 185/60R17.
https://www.suncoastparts.com/mm5/me...ct_Code=997STK
Wondering how much this matters.
bigger is better
Running some numbers around my base rear tires, 295/30R19
A 185/60R17 is nearly identical in size being 0.7" off in overall circumference.
A 195/75R18 is 11" off in circumference! That's 90 revs per mile difference between the inflated spare and the stock tire that the diff would have to compensate for. For me, that's too much and suspect it would add unnecessary wear or overheat the trans oil.
So IMO, while it might mount up I wouldn't run it on the drive wheels. The front of a C2 wouldn't be a problem but of course that won't be the one that goes flat...
