Wheel Offset
Front 19" x 8.5" 45 Offset
Rear 19" x 11 50 Offset
My stock rims are:
Front 19" x 8 57 Offset
Rear 19" x 11 67 Offset
Guy tells me that the rim will fit a narrow body car only. Help me out with the figures above because those offsets seem way off compared to the stock. I wouldn't mind if the wheel came out closer to the edge of the fender more but I'm unsure how to calculate.
Your current rims are the standard 997 NB offsets. what you do do to quickly calculate the rear offsets since both wheels are 19 X 11, is measure the distance that your 67 offset wheel ( and tire) can be "pushed" out towards the edge of the wheel well.
IMO, the rears can pry come out another 7 to 10 mm and then the wheel/tire starts to come out a little too much from the fender edge. so that effectively changes your offset to a 60 , or even a 57. Im not sure if your car ( Carrera S in your sig can accomodate the additional 7mm.
The 50 Offset is a little too much, so I can't see it fitting well on the rear.
with the 8.5 inch front ( 1/2 inch increase in width) , it is already offset( pushed out) approx 11mm, so it should be about the same as your 8 inch wheel minus 11mm, i.e. 46 mm offset.
take a pic of the wheels you are looking to purchase; there may be a member here who has them.
