Airbag warning light after ssk install
I finally finished installing oem ssk just now. It wasn't easy but with help of diy posts in this forum, I managed to get it done. I drove the car around the block to test it out and it's wonderful. However, I noticed that the airbag warning light was on when I started the engine. I removed side knee bolsters to make sure the connector for wire bundle was not disconnected and it was fine. I can't think of anything that I did wrong to cause this warning light to be on. Has anyone had same issue after ssk installation? Could anyone help me with this issue? Thanks in advance.
Yes...that little effen airbag light can be a nascence. You'll need to get it reset at the dealer. If you had your doors open for a long time with the lights on an it ran you battery down past (I think) 12.6 volts that damn light can come on.
if you have a good relationship with an indy (or maybe a stealership) they might do it for free. but unfortunately they might rape you for an hour's worth of labor for what is a simply 2 minute fix.
OR...find someone with a durametric pro. like me. i work/live in MD, in the gaithersburg/germantown area - if you want to cross the bridge, i can do it for free. i had to clear mine also after removing ctr console for shift cable replacement. FYI, i will be at the VIR DE this weekend if you are also going...
I really appreciate your offer for resetting the light and I might take up on your offer. I will pm you sometime next wk. Thanks again. Have fun at DE.
I don't know what may have caused it to come on. But, I've learned to NEVER turn your car on if you disconnect anything electrical. The way these circuits are monitored, you never know what warning light might illuminate.
Do you remember turning the key at all while the console wiring was disconnected?
def simple, but unfortunately without a durametric, you are at the mercy of a stealership or an indy, some of which who want to rape you an hour of $ for a 5min job.
AFAIK, the durametric pro is the only consumer tool that can do it. the durametric enthusiast cannot.
Considering the liability associated with airbags, it's no surprise a dealer or Indy trip is mandated to have this reset. It's a lifesaving system and can't have just anybody resetting faults.
We may know what most likely caused it. But coincidentally, could something actually be wrong with the system? I wouldn't want to find out the hard way it won't work when needed.
Brian
Brian
Brian
Brian
Spiff,
Agree. But my point was more to the availability of tools for the "average idiot" to use on reseting the light. You yourself said there was only one "consumer" tool. I was merely trying to rationalize why that may be.
Plus the airbag is designed to save your life after you've unsufficiently torqued your centerlock. You're already in trouble when your relying on it. Perhaps airbags were invented initially just for us do-it-yourself guys
Brian
Brian
