Bridgestone RE50 tire help question for GTS
My tpms sensor was telling me I was low on air so I set my tire pressures to 34/37 which is for cold, but living here in hot las vegas, should I have set it to something higher? I use a longacre gauge and don't go by the tpms sensor reading to set it. Should I be using higher air pressures since its currently really hot in vegas right now and if yes, what should I be setting it at? Even at night its above 90 degrees here. :\ And the nearest station with air is a few miles away so by the time I get there it does go up so I was thinking I should use a hot tire setting, but I don't know what it is since it's not listed in the manual or door jamb.
Thanks to anyone that can help. This probably sounds like a really lame question, but I have never had a car of this caliber that had technology like this. My former sports cars (nsx, and supra turbo) never had this tpms technology.
For a light load and any type of spirited driving go with the 34/37psi. Adjust the pressure cold....like at night or before you go to drive and the car has been sitting out of the sun. Also keepmin mind that when the car sits out in the sun and it shines on 1 tire and the other tires are in the shade your psi will show higher on the tire in the sun.
P.S. - Many will disagree, but this is what is correct; just check the Owners Manual for 997.2 and newer where PAG clearly pegs cold temp pressure to an absolute reference - 20C/68F. Set this way, second gen PTMS will be spot on no matter the ambient temp. The Longacre pressure gauge with temperature compensation does exactly that, when used correctly.
I bought a cheap one at the hardware store. It works great for putting in a pound here or there.
so which would that be, set them lower, or set them higher...kinda covers everything there...
Go get a small air compressor that you can use at one to put air in. Then you can use he chart ADias posted. Once you drive the car the readings won't count because the tires get warm and the pressure increases.
No! You set them 2.7PSI higher (36.7/39.7). Make sure that you do this with your car engine cold as the 911 engine contributes to the temp of the rear tires.
No no no you don't change the tire pressure depending on the outside temps.....34/37 COLD and leave it there. The chart is only showing you due to outside temps how the tire pressure will fluctuate.
You should check you tire pressure every week or so to make sure it's good.
