One week off - do I need to trickle charge?
Old 08-10-2012, 04:16 PM
San Rensho
San Rensho's Avatar
Shouldn't need a trickle charge, but pop the trunk in case the battery does go dead so you don't have to mess with jumping it from the fuse box.
Old 08-10-2012, 04:18 PM
Mike in CA
Mike in CA's Avatar
You will probably be ok but I agree with others that there is no reason not to leave it on the maintainer. Unless your parking arrangement makes it difficult, what's the downside to leaving it plugged in?
Old 08-10-2012, 04:54 PM
PHX 911
Official Rennlist Snake Slayer
PHX 911's Avatar
Won't the trunk illumination light then kill the battery?
Old 08-10-2012, 05:25 PM
Mike in CA
Mike in CA's Avatar
The light will turn off within a couple of hours. Just FYI to the OP, the remote locking is on standby for 7 days so there is drain on the battery from that source, if not others. More good reasons to use the maintainer....
Load switch-off after 2 hours or 7 days
If the ignition key is removed, loads which are
switched on or are in standby mode (such as the
luggage compartment light, interior light and
radio) are automatically switched off after approx.
2 hours.
If the vehicle is not started or unlocked with the
remote control within 7 days, the remote control
standby function is switched off (to save the
vehicle battery).
1. In this case, unlock the driver’s door with the
key at the door lock.
Leave the door closed in order to prevent the
alarm system from being triggered.
2. Press button 1 on the remote control.
The remote control is now activated again
Old 08-10-2012, 05:43 PM
Mbiondo
Mbiondo's Avatar
Wait, you're going on vacation and leaving your 911 all alone in the garage for a week? Shame on you.
(Just kidding)
Old 08-10-2012, 06:06 PM
pissedpuppy
pissedpuppy's Avatar
nah. I travel a lot, usually 10 days or so at a time, never needed one
I might be tempting fate, but if I blow a battery I'm getting a lightweight one for sure
Old 08-10-2012, 06:34 PM
Domer911
Domer911's Avatar
Originally Posted by Mojo31
That did not happen with mine after a two week vacation in July.
..and so I guess you thought nobody was messing with your car while you were gone?
maybe yours is gen.1. My .2 functions that way like clockwork.
Old 08-10-2012, 08:44 PM
TxBob74
TxBob74's Avatar
[QUOTE=Mike in CA;9755910]The light will turn off within a couple of hours. Just FYI to the OP, the remote locking is on standby for 7 days so there is drain on the battery from that source, if not others. More good reasons to use the maintainer....
Or you can just pry the trunk light out (small screwdriver under the lens from the bottom) and disconnect the light. Pulls straight off. If you are quick enough after popping the frunk you won't burn your fingers.
I started doing this when I couldn't identify its fuse or decipher any switch that operates the light. Perhaps it's the latch? Two hours burn time annoys me. Since I use alligator clips with the Battery Tender, I leave the frunk open.
Old 08-10-2012, 09:54 PM
Mike in CA
Mike in CA's Avatar
I didn't want to get into that in my previous reply, but I've done something very similar and disconnected the wire behind the light. This way the bulb is still in place and I can quickly reconnect the wire if needed. Obviously, both our solutions get the same result .
I have the more permanent quick connect plug installed on the battery for my CTEK so I also leave the frunk ajar for charging. And like you, the 2 hour burn time for the luggage light annoys me.
Old 08-11-2012, 01:58 PM
sullivas
sullivas's Avatar
Can never hurt to put it on trickle. Peace of mind and a healthy battery.
Old 08-11-2012, 02:03 PM
mjsporsche
mjsporsche's Avatar
If you have the trickle charge, just plug it in. It is good for the battery.
Old 08-12-2012, 01:18 AM
ricm
ricm's Avatar
Default Use it!
If you have a maintainer, use it. It's a PITA if your battery dumps.
Old 08-18-2012, 10:12 PM
mgordon18
mgordon18's Avatar
Just to wrap this up...
I plugged it in. I figured I'd never used the charger before and it was worth trying it out now, when it's only 7 days, rather than screwing it up for some stupid reason when it's a month or more.
Needless to say, she started right up.
Also, I didn't have any problem with the key resetting. I'd left it unlocked in the garage for the week, so I didn't need the fob to unlock. When I got to my destination, I got out and locked it with the fob with no problem. Maybe the key reboots when it's placed in the ignition...
Anyway, thanks for the opinions.
Old 08-19-2012, 12:19 PM
Mojo31
Mojo31's Avatar
Mine is '09 997.2.
I left it unlocked though.
Old 08-22-2012, 06:56 AM
seapar
seapar's Avatar
I plug it in if the car will be idle for a week or so. Besides it makes it less likely my wife will take the GT3 for a joyride if she has to disconnect it (Battery terminal hookup) :-)
But I just got another ctek that has a cigarette lighter plug in connection so she can hook up her Boxster herself.
Quick Reply: One week off - do I need to trickle charge?
