Battery Drain!!
Old Jul 26, 2012 | 09:15 PM
ricm's Avatar
ricm
Originally Posted by petee1997
Why do you refuse to use a battery tender. My car is plugged in unless I plan on driving it daily. The car is flawed and no amount of complaining will solve the problem.
I'm not refusing to use a tender; I have one. Just thought that a new battery, 90-100F outside temps, and a two week absence would be OK. I hope the tender doesn't present new problems as my car is almost out of factory warranty and I wonder what the after-market warranty will cover.
Complaining? Yea, I guess I'm surprised and frustrated to be required to use such a band-aid, especially with the high price of admission for a "flawed" vehicle from a maker with a such a long history.
Old Jul 27, 2012 | 09:21 AM
GSIRM3's Avatar
GSIRM3
Originally Posted by No HTwo O
For the car to go into sleep mode, the doors need to be closed, locked and the alarm activated. After about 5 days, the car enters sleep mode to save battery life. You will not be able to open the doors with the remote key fob. You need to unlock the door with the actual key, and within about 30 seconds you need to insert the key into the ignition, and turn to position 1. If not within about 30 seconds, the alarm will sound. You do not have to actually start the car. This reawakens the car. It will go back into sleep mode again in about 5 days.
I thought that might be what he was referring to. On all three 997 I have owned, including my 2012 GTS, all you have to do to "reactivate" the remote function is to unlock the door as you said, then with the key still in the lock, push the lock/unlock button on the remote, and the remote function is reset. No need to put key in ignition.
I just came back off of a 2 week vacation and left my car in "sleep" mode (well after about 7 days it goes into sleep mode), and it started right up, no hesitation or indication of a weak battery at all.
Old Jul 27, 2012 | 09:36 AM
No HTwo O's Avatar
No HTwo O
I'll have to try this way next time. Thanks.
Old Jul 27, 2012 | 09:37 AM
jhbrennan's Avatar
jhbrennan
Batteries are "consumables" like tires and wiper blades - doubt the aftermarket warranty will cover. BWM's have similar battery issues and their owners complain too.
Old Aug 3, 2012 | 01:48 AM
Shtootgart's Avatar
Shtootgart
Went away for a week with trickle charger on (attached directly to battery terminals) and came back to dead battery. Mechanic told me it was probably because light inside trunk was on and to be sure to switch that off while charging.
Old Aug 3, 2012 | 02:05 AM
Devil Boy's Avatar
Devil Boy
Lately I have had extended business travel lasting months at a time. I completely unplugged my battery because my car sits in a storage unit that has no electrical hookups. Last time I came home I reconnected the battery and it started up just fine. Once I drove about 100 meters the PASM and other alerts went away.
Old Aug 3, 2012 | 03:04 AM
Bijan's Avatar
Bijan
A trickle charger will supply about the same current as your trunk light needs, so your battery will become depleted if it remains on.
I feed the cable through the gap at the back of the lid between the wipers so the lid can be closed.
A higher amp charger 3 or more Amps (such as Porsche or CTeK) would help.
Old Aug 3, 2012 | 03:28 AM
scotsskier's Avatar
scotsskier
Still pretty much bs that you should need to do this with a car like this. My wife had a new 335i that had 3 batteries in 15 months! I had a "come to Jesus " meeting with the regional service director since she was totally p****d and reluctant to leave the car at the airport. When we were discussing I pointed out that I could leave my explorer parked for 6 weeks and it would start immediately but if the Beemer sat more thana week it was a crap shoot whether it would start or not. He responded "ah, but that is a ford, this is a BMW, completely different quality of engineering, you need to plug the battery tender in for more than a week... ". Then realized what he was saying . Needless to say they pulled out all the stops to fix it then and, funnily enough never had problems after that..
Oh, and I have disconnected the trunk light on the cab....
Old Aug 3, 2012 | 04:15 AM
boolala's Avatar
boolala
I've fully recharged my battery many times with the trunk open and trunk light on. The trunk light will turn off automatically after about 4 hours. Never bothered pulling it. I doubt that little trunk light could drain your battery anyway.
Old Aug 3, 2012 | 09:02 AM
jhbrennan's Avatar
jhbrennan
Obviously the mechanic doesn't know that the power shuts off to the lights after a period of time
If the ignition key is removed, loads which are
switched on or are in standby mode (such as the
luggage compartment light, interior light and
radio) are automatically switched off after approx.
2 hours
Old Aug 3, 2012 | 12:14 PM
Shtootgart's Avatar
Shtootgart
He did show me the switch to turn off the trunk light but you are right, he probably didn't know it went off automatically anyway. Let's see what happens and if it fails again, may have to go with cigarette lighter charger or CTek
Old Aug 3, 2012 | 12:44 PM
USMC_DS1's Avatar
USMC_DS1
If you lock the car those systems will shut off sooner as well. Otherwise I believe it takes up to 4 hrs before they shut off with the car turned off but unlocked. Just get in the habit of locking it even though it's in the garage.
Old Aug 3, 2012 | 01:10 PM
Shtootgart's Avatar
Shtootgart
The PO was a doctor that didn't drive the car much and he told me he just disconnected the battery. That means reentering the radio code each time etc. PITA. Hope I can get a charger that works or figure out a a way to drive this baby every day !
Old Aug 3, 2012 | 02:10 PM
zanwar's Avatar
zanwar
I had a battery drain problem with my previous 997. It was fixed under warranty. They had to replace some wiring from the battery to the engine compartment.
Old Aug 3, 2012 | 08:09 PM
Shtootgart's Avatar
Shtootgart
Looks like mine might be a cooling fan sensor issue. Mechanic noticed fan coming on at random while car was off and replaced sensors ($100 in parts) and thinks I'm good to go. Maybe something for some of you to look into.
